H-3 Controls
HabitatStewards.org View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HabitatStewards.org Quote  Post ReplyReply Direct Link To This Post Topic: H-3 Controls
    Posted: 15 Aug 2011 at 3:44am
Hello All! I just purchased an H-3 and need some instruction on opetations and controls identification. if someone could give me a run down as if I was sitting in the seat would appreciate it! it has PTO as well, which I think is the small lever below my left leg. I don't quite understand how to turn? Thank you in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote HabitatStewards.org Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 10:52am
Hello All! I just purchased an H-3 and need some instruction on operating and controls identification. if someone could give me a run down as if I was sitting in the seat would appreciate it! it has PTO as well, which I think is the small lever below my left leg. I don't quite understand how to turn the unit? Thank you in advance!
Sorry for the typos in the inital post.  Thank you in advance for your assistance
chevytaHOE5674 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 11:37am
Main engine clutch is the pedal on the left side closest to the center. Push that and shift it into gear. The shuttle clutch (if equipped) is the large lever on your left side. Push it forward to go forward and back to go back. The levers in between your legs are the steering clutchs and MUST be used when turning. To turn slightly left just pull the left clutch handle. To turn hard left pull the left clutch handle and apply the left brake (pedal on the outside left) To turn right do the same with the right clutch and brake.
The pto shifter is small and close to the center on the left side. Push the main engine clutch in before shifting it in or out of gear.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2011 at 3:47pm
I've had my H-3 for 20 years and the instructions above are correct. Pulling the steering clutch lever back desengages the drive to that side but does not gaurentee that it will turn. That is when you use the steering brake but remember always use the steering clutch first. Pulling both steering clutches at the same time will stop the crawler. You will have to be very carefull loading and unloading or on steep slopes. Too much to explain here.
