H3 Brake Band - Lining Kit
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: H3 Brake Band - Lining Kit
    Posted: 13 Mar 2015 at 4:11am
Looking for a brake band lining kit for an H-3 or HD3.
The band is good just the material is worn down getting close to the rivits.
Was hoping to drill out the old rivits and put new liners on.  Anyone know of vendors that sell just the liners and rivits?
I see General Gear has aftermarket bands but would prefer to keep the OEM Allis Band that is in good shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 5:35am
Search brake band re-lining, in your town.  Around here, wareheim brake in Baltimore used to do it.  I haven't had the occasion to look up if they are still in business...
ivan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ivan Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 7:27am
we can help 989-379-2721
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2015 at 9:16am
McMaster Carr - sells band material but you will need a rivet press or access to one ad also drill and countersink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 12:17pm
Many thanks gentlemen for the wonderful input.  Appreciate the insights Coke and Dave.
No reline specialist so am doing this myself.
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2015 at 5:36pm
You might also be able to bond the material, with an epoxy type material.  You might have to look up the right stuff.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2015 at 10:37pm
The riveters are available from several of the suppliers for light aircraft brake pads/rivets as well.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2015 at 5:00pm
Couple of Items to share - this is a 1962 machine.
A single brake band contains 7 pads - 2" width x 3 5/8" length.
Total of 28 brass rivets needed to install all pads- one lining.
Assuming at some point AC Industrial Engineers realized the merit of a single continuous lining as opposed to 7 individual sections.
Thank you for the good information guys.... Orangeman
Edited by orangeman - 18 Mar 2015 at 4:11am
