H3 3-pt, PTO guard and tool box
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Topic: H3 3-pt, PTO guard and tool box
    Posted: 28 Sep 2021 at 3:22pm
My H3 has a 3pt hitch but it’s missing the lift arms and adjusters. Can’t seem to find a parts listing. Does anyone have any info about where I can get the original style. I can do a modification and use generic stuff but I’d rather have the real McCoy.
I’d also like to find the PTO guard shown in my literature. It looks simple enough to make but prefer actual part.
Also would like a real or reproduction fender toolbox. does not have to be in perfect  condition just authentic.
Part # or manufacture names would also be helpful. Anything to help with the hunt.
Thank You
1962 H3, WD45, B210
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 4:07pm
The parts breakdown for the three point hitch is in the 1066 Loader manual for the H-3.
I lack the ability to post pictures and documents on this site, unfortunately. The loader manual is form TPL-451A.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 4:18pm
Thanks Curt! Just so happens I ordered one from eBay yesterday. I like your AC collection by the way. I have a few B210s and a respectable assortment of implements. I was in the middle of restoring one until I had to relocate.
1962 H3, WD45, B210
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 2:10pm
Good luck with your pursuit of a hitch. My HD3 has one.
Curt Anderson
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 8:39pm
Thanks.  Would you mind telling me where your control valve is located and does it have a float position? Mine is on the right fender and does not have a float option. I’d like to convert mine if possible.
Thanks
1962 H3, WD45, B210
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2021 at 9:34pm
I have a diverter valve on the dozer lever. Essentailly lift the blade and divert the flow to the 3 point. I don't normally use it consequently I don't have it installed. The dozer valve has  a float  position.
Curt Anderson
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2021 at 2:38pm
Curt
I looked at my operators manual for the 1080 setup and can’t find the float position. Can you help me out?
Thanks
1962 H3, WD45, B210
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2021 at 5:51pm
If you have a loader you may not be able to use a diverter valve. The raise lower
function of the loader valve has a float position. You may have to add a valve if you need the float function.
Curt Anderson
Beam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beam Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2021 at 4:12pm
I don’t have a loader I have the 1080 fully hydraulic 6way blade.
1962 H3, WD45, B210
