H11b Clutch fluid system.
honeycuttcars View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Topic: H11b Clutch fluid system.
    Posted: 21 Feb 2018 at 1:01am
Hello to all, I recently bought a 1964 HD11b, and have a question about the clutch fluid/lube system. My problem is I have a pretty good leak coming from the top of the tank where the 1" hydraulic hose connects to the jic fitting, or within that area. (Return side) I have had the hose off, and it appears to be o.k., and resealed the jic to the npt fitting, but still I have a leak when running. My question to you is that parts book shows a screen under the fitting, inside the tank, could it be so plugged up that it is forcing the oil out of anywhere it can go? Also, does anyone know what spin-on filter goes onto the pressure side of the clutch lube system? I have the A/C number, but does it cross reference over to another filter? Thanks for any help....
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 3:23am
I do't tink the screen is plugged you could check the gasket oil tank cover maybe brook or check for crack on oil tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 10:19am
Thanks for the reply, this morning I pulled the starter off, and then removed the assembly from the top of the tank. It looks like the leak might be coming from the oil tank adapter. I will try to disassemble it and reseal it. You are correct, the screen was clear when I looked down into it. I hope I can correct it without having to have a 4-wire hydraulic hose made up. (Not cheap)
Anyone have a cross reference number on the filter, or will a standard Baldwin hyd filter work? Thanks...
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 12:31pm
go to
look at the parts books and find the AC number for the filter and see what it will cross to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 12:34pm
The AC number is 4511629, but I was asking if anyone had a cross ref. they were using. Most of the filters I have bought have been NAPA brand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 12:41pm
found this
looks like a Fram PH8A
Edited by CAL(KS) - 21 Feb 2018 at 12:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 3:09pm
I will Check that out. I have cleaned and resealed the screen cap and the jic fitting, and will install it in the am. I saw no cracks or bad areas in the copper gasket in the cap. I did de-burr the housing around the seating surface, I hope this will work. Thanks for all your help. I will post a conclusion when I can.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2018 at 3:56pm
PH8A is the older Ford pickup and car filter plus others. Stupid keyboard!
Post Options Post Options   Thanks (0) Thanks(0)   Quote honeycuttcars Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 1:30pm
This morning I went up to the shop and reassembled the pick-up assembly and then reinstalled the starter. (Bottom bolt on the starter is a #%& to get to.)I fired it up and have corrected the leak...
Thanks for all that responded to my post.
Edited by honeycuttcars - 24 Feb 2018 at 9:26pm
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 4:59pm
Congratulations on fixing the problem.
Well done.
This page was generated in 0.107 seconds.
