Guess What The Tools Are For
 Post Reply Post Reply Page  <123>
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 6:27pm
Yep! I knew you weren't poking. Many people don't know what a Stillson is, so you're not alone! It's kind of like a Crescent wrench. It's just a brand. Stillson=pipe wrench, Crescent=adjustable wrench.
Even in Oklahoma I've experienced different terms for brushhog. In NW OK, it's a beater. In the SW it's a shredder. In central OK it's a brushhog or a bush hog. Lol
I have a grandpa in the SW, a grandpa in the NW, and all my friends here in the central region. I have to make sure and use the right term for the region I'm in, or no one understands what I'm saying! LOL
Reminds me when Gilbert Vust would refer to the "Oklahoma Ratchet".  It was a Crescent wrench.  LOL
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:19pm
My entire life I was told to "Go get the green handled pump pliers".
I think I was in high school before I heard the brand Channel Locks.
The mechanic always wins.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:27pm
Me too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:41pm
Never having run a combine, exactly what happens when you plug the cylinder on an All Crop? Does the belt smoke, or is there a slip clutch, or snub the tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 7:49pm
Sometimes a clutch will slip on the PTO driveline, but usually it stalls the tractor.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 11:05pm
[QUOTE=WD45]The rod - short one was used to turn the cylinder over when one plugged the cylinder. You opened the side door behind the cylinder and pulled as much straw out of the cylinder while turning the cylinder back and forth until the cylinder was freed up.[/QUOTE
 x2
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 11:19pm
and it was a nasty job when it was HOT!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 11:30pm
Worse than being under a Gleaner on a hot day getting covered in all the dust/straw/chaff as it falls on you?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:37am
Originally posted by KY poorboy KY poorboy wrote:
I didn't have my stick out doing any pokin. I honestly have never heard that term before. I figured that was what it was, but just wanted to know. It amazes me how many different areas have different names for things. As I was growing up in poor ole KY, they were called monkey wrenches. I just call em pipe wrenches.
When I started farming and looking for equipment, it made me no difference how far I went to get a good deal, so I looked everywhere. It took me a while to figure out what folks way down south called a "harrow". Here we just call it a disk. A harrow to me is a spike tooth drag, or something similar. Sooo,,, I was just curious. LOL
I'd never heard "Stillson wrench" before either. Google / wiki is awesome! lol Monkey wrench is like a pipe wrench, but smooth jaws instead of serrated. At least that's the way it was in Grandpa's workshop in MI.
Harrow, well, we had a bunch of old operator manuals or books on various things we had. The books titled like "disc harrow" "spike harrow" "spring tooth harrow". Seems anything that moves dirt without rolling it all the way must be a harrow....'cept a cultivator? In Canada, they have heavy harrows, light harrows....
This conversation is a harrowing experience
Edited by Tbone95 - 15 Nov 2016 at 6:39am
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:48pm
 Well you guys did pretty good. I thought you would get the tool #1 but not tool #2. I need to make it harder.
 Tool #1 to turn the cylinder backwards to unplug.
Tool #2 to raise and lower the side hood.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 5:51pm
Is that 2nd pic on an early 66 or a 60? My 60A's don't have any kind of loop for the hook.
I figured that slug bar would be longer! Give you more leverage!
The one I have (In case I ever have to use it) is about 5' long, and and inch in diameter that tapers on the end, to fit in the cylinder shaft hole. Needless to say, it's not Allis! LOL
Edited by CrestonM - 15 Nov 2016 at 5:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:05pm
 The combine in the picture is a 60A.
Parts book says prior to S/N 69101.
I have yet to plug one so not sure how much pressure is needed to turn backwards.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:27pm
Ask anybody that ran a pull type at Hutch in 2015! I think I was the only one who never slugged, but I could be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 6:52pm
 Was it wet last year?
Thanks & God Bless
Dennis
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 7:45pm
      Creston.......there is a (cough,cough) slip clutch, (cough). Dennis my man, I have been wondering ever since you posted the pictures, and since I am around Allcrops everyday , where were the tools stored on the combine ? Ryan searched the machine shed tonight looking for the slugger bars. The hood hook had to store on the combine as well ? I remembered the slug bar on the "E" being mounted on the side of the elevator .
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 8:00pm
 They just sat on top of the cylinder housing behind tailings spout.
Thanks & God Bless
Dennis
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:31pm
Long time ago when my grandfather combined with his 66 we used the long rod to poke the bridged oats out of the hopper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:36pm
Nothing held them down?
Also...off topic, but while we're talking about mystery objects...do your combines have those 2 angle iron brackets on top of the separator? One is about 7" long, and the other almost as long as the width of the separator. Mine have them, and I saw a couple at Hutch too, but no one knows what they're for!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:37pm
Yes. I believe there was a half inch of rain one of the nights of the show, but we could still get in the field, so the show went on!
The grain was so soft, it barely had any crunch when you bit it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2016 at 9:52pm
 Just gravity Creston.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:43pm
     Dennis, there is no way in the world that Allis engineers did not devise a storage place for these two metal tools. I can bet the farm that customers were not told to just toss them on top of the cylinder cover and hope that you do not ever hit a ground hog hole or large wash out. Two long pieces of metal riding "loose" so that either one or both would run through the cylinder. Ryan and myself had just enough time tonight to look over the 66 for possible lock downs, nothing. There has to be some info or brochure out there. Saying that, I am surprised that I have never seen either tool on a used Allcrop ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 7:51pm
that's the same place ours was stored too....nothing to hold them there cept their own weight. never had either one ever bounce out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:20pm
    I just have a very hard time with the dealer or who ever saying "here are some extra tools that you will need, just throw them up there".  Maybe that is why no one has ever seen the (mystery tools) again.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 8:36pm
Those tools set were placed above the cylinder and never fell out on our combine. My sister and I would sit on the deck with our feet sitting over the cylinder were these tools set and we would ride by the hour watching the grain coming up the canvas on the 60 then 66.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:02pm
   Can not believe that any one else would be crazy/foolish enough to sit up there. I did it for several hours filming Ryan's restored 72. Thank god OSHA wasn't around.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:34pm
I'd be  scared doing that, knowing one chuck hole could throw me onto the canvas! Yikes!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:40pm
 They will not fall out. That part of the housing is curved back towards the walker area and there is angle iron on the front side so they can't go forward.
 I pulled All-Crops down the road at around 50 mph (when I have a clear line of sight) and a combines will bounce a lot but the tools just ride with the machine. The combine does not bounce as bad when in the field.  I can't say that I ever hit a hole in the field yet but I have hit bumps in the road that made the unload auger unhook and swing down and the tools all made it home.
Edited by DennisA (IL) - 16 Nov 2016 at 9:43pm
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:44pm
Yep...that surprised me the first time it happened!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:49pm
 The first thing I do after hitching the combine behind the truck is tie up the auger.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:53pm
I guess they're the ones with wheel bearings?
