Group 31 Batteries |
| Author | ||
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12343 |
Topic: Group 31 BatteriesPosted: 25 Dec 2025 at 1:51pm |
K, dumb question I guess. If a stud (post) can wiggle, albeit slightly, is that a problem?
| Sponsored Links | ||
Les Kerf
Posted: 25 Dec 2025 at 1:57pm |
It sure can be a problem, but it also might work fine for a long time. It is certainly not desirable, and I wouldn't want it on any machine/vehicle that I considered to be critical.
Tbone95
Posted: 25 Dec 2025 at 2:23pm |
That’s kinda what I was thinking. It sure didn’t come new that way. I think I’ll take it back where I bought it and see what they say. Friggin’ paid enough for it that’s for sure.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8778 |
Posted: 25 Dec 2025 at 8:30pm |
Sounds faulty from the get go. They don't come loose with normal use and should take some abuse as well before that happens. Worst case is poor connection internally and hydrogen BOOM!
1963D17
Joined: 05 Jun 2021 Location: Alvord, Iowa Points: 95 |
Posted: 30 Dec 2025 at 4:00pm |
That post attaches to the grid plates. Quality group 31's use a 1/2" rod to the grid. Cheaper one's a 3/8". When they wiggle the rod is usually corroded and getting thin allowing the stud to move. This is made worse by the farmers best friend. Using his pliers to wiggle off the cable instead of prying it straight up.
SteveM C/IL
Posted: 30 Dec 2025 at 9:11pm |
A stud post should not require any prying. Remove nut and lift coble off.
1963D17
Posted: 30 Dec 2025 at 11:22pm |
Missed the stud type. Both my 7120 Magnum and 1660 combine have that style.
Tbone95
Posted: 31 Dec 2025 at 6:35am |
Well I'll be taking it to the store Friday, we'll see what they say. Battery is only 7 months old.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12051 |
Posted: 31 Dec 2025 at 7:58pm |
Ditto to what Les said. Loose posts can cause a lot of electrical gremblins.
Steve@B&B
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1597 |
Posted: 02 Jan 2026 at 6:31pm |
Well?
Tbone95
Posted: 02 Jan 2026 at 8:20pm |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1545 |
Posted: 03 Jan 2026 at 4:46pm |
Stud post batteries are great! The entire trucking industry runs on them. But you can also damage them if you use too long of 9/16 wrench on them. And never use a gun on them! Lol. I use short wrench or ratchet and snug carefully. Not sure what the torque would be Maybe 15-18 ft lbs at most. I have never torqued those. Just be careful. 😀😀
Tbone95
Posted: 06 Jan 2026 at 7:50am |
Well, guy at the parts store said yeah that’s not good, I’ll grab you another one! I noticed the other stud on that battery was slightly loose also.
As far as what Ed just said, I don’t think I over tighten them. One can just sort of sense that’s not the strongest thing to reef on. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5212 |
Posted: 06 Jan 2026 at 10:38am |
Yes the trucking industry has almost gone to exclusively Group 31 stud post batteries. They are supposed to use LEAD nuts that will NOT over torque the stud but have the nut strip out. Then some Yahoo just goes to the hardware bin and grabs a 3/8" coarse thread nut, then the problems begin. Locally I can buy a quality 7 year Group 31 stud post battery for under $100. Whereas a small 5 year car battery is close to $130. I use Group 31 stud post batteries in everything that they will fit in. That way when the big truck gets a new set I can use the good singles until they give up.
Tbone95
Posted: 06 Jan 2026 at 11:00am |
Be nice if they’d supply the dang nuts! |
SteveM C/IL
Posted: 06 Jan 2026 at 1:36pm |
All 10 of my stud post 31's have stainless nuts. That's what they sell at the truck dealership. Neve seen a lead nut. No issues for 42 yrs.
Les Kerf
Posted: 06 Jan 2026 at 4:44pm |
This is the first I ever heard of lead nuts on battery posts
PaulB
Posted: 06 Jan 2026 at 8:02pm |
The new Freightliner I brought in 1986 had them and the local HD truck parts place and local battery store have a bin for them. I've never seen anything but soft battery nuts for OEM parts. I have however seen many standard hardware nuts on things I've worked on over the years. Very much like the special battery bolts for side post batteries. They are made of a softer material and have a 5/16" or 3/8" hex so the wrench ape can't over torque them.
