Group 31 Batteries
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Group 31 Batteries
    Posted: 25 Dec 2025 at 1:51pm
K, dumb question I guess. If a stud (post) can wiggle, albeit slightly, is that a problem?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2025 at 1:57pm
It sure can be a problem, but it also might work fine for a long time. It is certainly not desirable, and I wouldn't want it on any machine/vehicle that I considered to be critical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2025 at 2:23pm
That’s kinda what I was thinking. It sure didn’t come new that way. I think I’ll take it back where I bought it and see what they say. Friggin’ paid enough for it that’s for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2025 at 8:30pm
Sounds faulty from the get go. They don't come loose with normal use and should take some abuse as well before that happens. Worst case is poor connection internally and hydrogen BOOM!
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 4:00pm
That post attaches to the grid plates. Quality group 31's use a 1/2" rod to the grid. Cheaper one's a 3/8". When they wiggle the rod is usually corroded and getting thin allowing the stud to move. This is made worse by the farmers best friend. Using his pliers to wiggle off the cable instead of prying it straight up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 9:11pm
A stud post should not require any prying. Remove nut and lift coble off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 11:22pm
Missed the stud type. Both my 7120 Magnum and 1660 combine have that style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2025 at 6:35am
Well I'll be taking it to the store Friday, we'll see what they say.  Battery is only 7 months old.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 21 minutes ago at 7:58pm
Ditto to what Les said. Loose posts can cause a lot of electrical gremblins.
Steve@B&B
