Greasing the PTO universals in an AC Forty Five
Ian Beale View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Topic: Greasing the PTO universals in an AC Forty Five
    Posted: 05 Oct 2024 at 3:48am
The back three aren't so bad but the front one is a pain to get at from underneath.
But there is a rectangular bump over it in the front left hand corner of the cab floor.   And that has a squarish window cut out at the left hand rear.
So, if you take a torch (flashlight) and check as you turn the engine over by hand, you will see the grease nipple appear in that window ready for access.  Easier with two people but you work out where it lines up if on your own.
I found that by accident, not in a manual.
Edited by Ian Beale - 05 Oct 2024 at 3:51am
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2024 at 8:18pm
Seems sometimes someone figured it out but never informed others of the solution.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 2:47pm
Be nice if you could mark pulley so could see where to park it to lube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2024 at 11:17pm
You can mark the PTO drive pulley so you can see the mark from underneath while turning the engine slowly by hand.
I think you'd be lucky to get it positioned with the starter
