Grandfathers CA
 Post Reply Post Reply Page  <1 101112
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 2:27pm
Yes, I did replace the coil and condenser a month ago. It still misses after warming up.
Today all I did was change the points. It is clean and not grounded. Only the condenser and coil are attached to the point.
Edited by CA13414 - 19 Jul 2025 at 2:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 3:37pm
I did recheck everything. Not sure why, but I simply disassembled everything then put it back together. I was able to get a shock off the coil contact which was OK but not a hard snap of a shock. Must of had a contact and grounded out the coil somehow.
However, after timing the rotor gears there was nothing to the plug wires. I took off the distributor cap and with a screwdriver touching the coil contact, there was a shock. As well there is pressure on the cap contact rod, thus, I think this is OK.
Shop is hot and I am drenched. Back inside for a bit with a cold one.
Dan
Edited by CA13414 - 19 Jul 2025 at 4:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 3:40pm
Earlier I watched a "youtube" rebuild and the shock they had was an arc of about 1/2". Not what I am getting.
Maybe a rebuild however, not to keen on the idea of $325.
Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 6:01pm
However, after reading the various threads, everyone who bought a rebuilt magneto mentioned it was a very good move.
The "youtube" on rebuilding a magneto mentioned "recharging" the magnets! Is that a thing?
Maybe that is why "my shock" is a pansy ass shock.
Dan
Edited by CA13414 - 19 Jul 2025 at 8:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 7:59pm
i have several B tractors all with MAGS.. I have replaced coils and condeners and points as needed over the years.. I had ONE that was REAL STUBBORN on starting after a few years.. I took apart the the IMPULSE SPRINGs were weak and not retarding the spark to TDC when you crank.. It was OK when i turned by hand.. I finally got it to work "OK"..... couple months later there was a guy on this site going out of business and was selling his REBUILT MAGS... had  3 or 4... Said complete rebuild with RECHARGED MAGNET / new coil / NIS condenser / etc. ... so i bought it... WOW... what a difference.. Engine rolls over ONCE and its running.. HOT SPARK.. FANTASTIC... Never thought i would get that much DIFFERENCE !!
Edited by steve(ill) - 19 Jul 2025 at 8:00pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 8:30pm
Originally posted by CA13414 CA13414 wrote:
...The "youtube" on rebuilding a magneto mentioned "recharging" the magnets! Is that a thing?...
Yup, it is indeed a BIG thing. All else being equal, spark energy is (somewhat) proportional to magnet strength. And magnets lose strength as they age, requiring periodic re-charging. Back 'in the day' every significant tractor dealer had a magneto re-charging machine. I wish I owned one Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 8:32pm
Steve, so maybe a rebuild or different mag with a "recharged mag" will help?
Interesting. That may be the issue.
Dan
Edited by CA13414 - 19 Jul 2025 at 8:43pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 8:34pm
Les, thanks for the comment. All that makes since. Maybe the rebuild with a magnet "re-charge" is a good option as you and Steve mentioned.
Much appreciated to everyone!
Dan
Edited by CA13414 - 19 Jul 2025 at 8:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2025 at 8:48pm
Thinking about this and the role of the magnet..... to induce a current. If the magnet is weak, the induced current is weak, or for me a pansy ass spark.
Who here does a great job of "re-charging" a magneto?
As noted, I did find someone on the "internet" who does this but would feel more comfortable with someone here in the group who knows a good :re-charger!!!" :')
Edited by CA13414 - 19 Jul 2025 at 8:48pm
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2025 at 8:47pm
Are the magnets "alnico"? Common 1950s magnet chemistry. Alnico loses strength over time. More modern use ceramic that don't lose strength.
If you buy a pair of strong rare earth magnets off temu/Amazon you can recharge the magneto magnets. Mount to a bench vice and run your magneto magnets between them.
Don't pinch your fingers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 7:55am
here are a few good photos... half way down the page is the "magnetizer" to recharge oil magnets... guy has a "HOME PAGE" button at the bottom..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2025 at 1:35pm
Here is recharging a guitar pickup magnets, made of alnico.
https://youtube.com/shorts/26zdiZ6xRhw
https://youtu.be/ufhUd4wkPMs
There used to be a video where strong magnets were stuck, setting correct polarity of each, to the faces of a vice to control the space to slip a magnet between and charge it up.
Edited by jvin248 - 25 Jul 2025 at 1:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 53 minutes ago at 7:38am
Thanks Steve, quite an amazing process. Is neat to see how we use to do this with the magnetizer.
I also went to his home page and saw the AC collection which was awesome! There was also a number of fun links.
Dan
Edited by CA13414 - 20 hours 29 minutes ago at 8:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 50 minutes ago at 7:41am
Thanks for the links..... was neat to watch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 35 minutes ago at 7:56am
Appreciate everyone's insight into the Magneto and lack of spark. Has been fun to learn from everyone. :')
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 32 minutes ago at 7:59am
Despite the effort thus far in "rebuilding" the Magneto (cap, wires, points and etc), I decided to replace it with a distributor conversion kit. Will still try to re-magnetize the rotor just to do it.
This week, I ordered a drive unit and an electronic distributor from Steve at ""B&B Custom Circuits."
Excited to install this and get the CA back up and running!
Edited by CA13414 - 20 hours 30 minutes ago at 8:01am
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 20 hours 7 minutes ago at 8:24am
You will not regret switching to a pointless distributor Smile
Post Options Post Options   Thanks (1) Thanks(1)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 26 minutes ago at 11:05am
Dan the man!  Your order went out this morning (Sat) and is heading to you. I sent the tracking to your home email.  Thank you!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 4 minutes ago at 11:27am
Thanks Steve!
I am, as we message, rewiring for power to the distributor vs. it being a ground to the Mag.
Is a simple change to a 12V terminal on the toggle switch.
Will upload a few photos later.
Edited by CA13414 - 8 hours 24 minutes ago at 8:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 3 minutes ago at 11:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 30 minutes ago at 2:01pm
Finally installed the original tail light. I looks awesome and works well with the push pull light switch that we put together last summer.
I have wanted to install an Emergency rotating strobe light for road travel. There was already an extra hole in the fender, in front of original tail light. Thus, I drilled that out and put on the bracket for a rotating strobe light.. Can simply slip the light on or off the bracket as needed.
My goal is to make sure I am noticeable, when on the road, to iPhone distracted drivers!!!
Edited by CA13414 - 8 hours 12 minutes ago at 8:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 23 minutes ago at 2:08pm
Works awesome, with the push-pull light switch.
Edited by CA13414 - 8 hours 44 minutes ago at 7:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 20 minutes ago at 2:11pm
Finally, opened up the “key and switch box” and moved the "Magneto ground wire" to the 12V toggle contact to supply power to the distributor that Steve at B&B sent.
Now when the key switch is on and the toggle is switched on, the distributor coil will be powered.
Edited by CA13414 - 8 hours 13 minutes ago at 8:18pm
