Grandfathers CA
 Post Reply Post Reply Page  <1 891011>
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 7:08pm
Very nice!   Wish mine hadn't had 70 years of poor treatment.  It's going to look a lot better, but not that good :(
1952 CA13092
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 7:42pm
Thank you!
Ted J. told me early on about "farming in a tractor." I was lucky to find a tractor that I could "farm in" parts and pieces. In the end I expect I it is ~40%/60% our family tractor and the farmed in donor!!! If it was only the family tractor, it would have required rebuilding of engine, transmission and differential which were all seized up.
Dan
Edited by CA13414 - 19 Aug 2024 at 6:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 7:50pm
Unloaded at home.
It will take a bit to get familiar with how to control the lift and blade. I have a lot of sand to move around over the next weeks.
Here is a video of the first blade drop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 7:59pm
Thank you!
Ted J. told me early on about "farming in a tractor." I was lucky to find a tractor that I could "farm in" parts and pieces. In the end I expect I am 50%/50% our family tractor and the farmed in donor!!! Otherwise I would not have been able to make it look like this.
Dan
:) I'm intentionally trying to maximally reuse original parts even if I have to go to some extremes to try to clean them up (I could pretty them up more if I wasn't doing the reno long distance).  Main exceptions are select fasteners and the radiator.  Unfortunately, I made the wrong choice for a replacement radiator.  It was advertised as a CA replacement, but wasn't really.  It was close enough to make it work though.
I'd like to have it functional with a 3pt mod by october.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2024 at 8:06pm
Quote :) Unfortunately, I made the wrong choice for a replacement radiator.  It was advertised as a CA replacement, but wasn't really.  It was close enough to make it work though.
Agree, I bought an after market aluminum radiator which works well, however was not sized right. Had to really work to get the grill cover in place. It was about a 1/4" to high.... Uggg!
Edited by CA13414 - 18 Aug 2024 at 8:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 9:00am
While driving down the road could hear a clunking. This was also notable with a slight left and right turn. I think the final drive shaft needs adjusting but wanted to ask other and see what you think.
Here is a link to a video of the noise from the final drive.
Also another of the PTO slack which I think needs a few shims.
Edited by CA13414 - 25 Aug 2024 at 9:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 9:05am
Was able put our CA to work. Moved quite a bit of sand quite easily with the 6' blade. Thought I might need to add sides to the blade to make it a boxed blade, but it worked well. I suspect I moved about 5'ish tons + of sand.
After moving the sand then used the harrow.
After about 4 hours of work. She looks awesome. I got a ton of "thumbs up" from the neighbors!
Edited by CA13414 - 25 Aug 2024 at 9:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 9:11am
Towards the end of the day, I noticed she was running a bit off. Pulled the spark plug wires and she was not firing on cylnder #2. There was no spark and switching out the wires and plugs did not make a difference. Thus, took off the distributor cap and used a bit of emory cloth to clean up the contacts.
After that she was running smooth and even. Should probably buy some new wires, plugs, rotor and distributor cap.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 10:29am
It looks really good doing some work!
Yep, you'll either have to keep cleaning the cap up every so often to remove the corrosion, or get a new one. The tractor probably deserves one at this point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 12:05pm
Today, I noticed after about two hours of running that it was once again missing on number 2. Thus, took it apart to look. Have spark at the magneto coil but when I put it back together, nothing at the distributor cap/spark plug cables.
Thus, ordering new ones and will see what happens. Makes me think the rotor is the issue. Regardless, ordered the rotor, distributor cap, wires and new plugs.
Edited by CA13414 - 25 Aug 2024 at 6:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 4:01pm
Re the clunk, before tearing down the final, double check the PA wheel clamps...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 5:39pm
Thank you,
Not sure exactly what the "PA Wheel Clamp" is. I looked in the parts manual and the shop manual and didn't see it.
As well, a big thanks to Steve for the PDF shop manual. Happy to forward to others as needed.
Edited by CA13414 - 25 Aug 2024 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 6:08pm
Power Adjust wheels have cam locks (and if present additional motion stop locks)
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 7:25pm
I am not sure, but is this something that is on a CA
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:01pm
Thanks!
Power adjust wheels were standard on a CA (those sliding rails for adjusting the wheels in or out).  Yours appears to have them.
Edited by dfwallis - 25 Aug 2024 at 8:29pm
1952 CA13092
1955CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:08pm
Looking good! nice job you did. Nice to see another CA back to work.
I think I'm going to order one of those side steps now like you have. I have tractors parked so tight in my barn I can't climb on the rear like I normally do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:30pm
I'm thinking about do the same, but I'm thinking of adding some full length side rails to mount various weight racks and maybe supplemental hydraulic oil container.
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:39pm
Edited by CA13414 - 25 Aug 2024 at 8:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:42pm
Thank you!!!
I think I am still quite able at 61 years old, but the step is still awesome getting on and off vs. climbing up the back side.
Edited by CA13414 - 25 Aug 2024 at 8:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 8:45pm
Thanks!
Now I get it. Totally agree!
If that is loose, that could be the reason and the wheel is jumping around and causing the noise.
Awesome! I will check and hope it is that simple!!
Edited by CA13414 - 25 Aug 2024 at 8:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1955CA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2024 at 10:12pm
Aren't they a great tractor to drive. So much power for what they are. And nice and simple. I love the CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 9:10am
Dan,
 Very nice job on putting your new CA to work! The power adjusters are a project sometimes. At least on the WD series they can be rusted tight. But it is good to get them freed up to secure the wheels to the centers.
Sure looks good on the beach moving sand!
 Thanks for taking us along on your project!
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 9:09pm
Yes. It is a great little tractor! Even in soft sand it has done well. Can easily pull a full blade with only a bit of slipping in the sand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 9:14pm
Dan,
 Chris and Cheryl
Thank you!
When we assembled them, I did tighten them and remember that the last one did not turn as much as the prior. Thus, as mentioned, it is not centered. I will loosen the ones that are more than the other and then see if I can get them all tight and at about the same rotation.
That should center them for the most part? Correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2024 at 9:25pm
nice looking beach also... where is that ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 8:35pm
Put the new plugs, spark plug wires, distributor cap and rotor. It started right up and ran smooth.
However, was just thinking about a prior thread and how they lost spark after warming up and running for a while. I did try again on Saturday evening when it had cooled down a bit, and still did not have spark. Should've tired tonight before changing everything!
We will see what happens when we work it for a bit this weekend!!
Edited by CA13414 - 29 Aug 2024 at 8:49pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 9:06pm
Too purdy to get dirty :)
1952 CA13092
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2024 at 3:34pm
Did head out with the CA and was able to spread out the rest of the sand. Our orange friend really works awesome. Was able to pull up sand from the lake without much effort. It actually worked better on wet sand with better traction vs. the dry and loose sand I have been moving around.
Tractor worked well for about 2 hours then started missing again. Thus, I let it cool for about an hour while I shoveled some sand at the edges by hand. After that I restarted and it ran smooth again. I was back to full water temp about 10 min later, however, after about another 40- 60 min of work, it started missing again.
The magneto was hot to the touch.
I have a hard time believe this is is due to the mechanical part of the magneto. Thus, with new wires, plugs, rotor and cap, is this the magneto coil that is cutting out at high temp or the magneto condenser? Connections are tight. Maybe replace both??
Thoughts?
Dan
Edited by CA13414 - 01 Sep 2024 at 3:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2024 at 3:44pm
Overall moved another 5-7 ton of sand. Also hooked up the neighbors harrow and began to drag the beach. Stopped when it started missing again. Still was able to achieve quite a lot in a few hours. Will finish tomorrow AM.
Total time on our new little orange friend is 11 hours (8 hours spent on moving and grading the sand).
Edited by CA13414 - 01 Sep 2024 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2024 at 8:55am
A shout-out to my wife Kari who has been writing while I was busy with our family CA rebuild.
While I was "Tractoring," she wrote a book!!! Thus, here is my shout-out to her.
My better half, a "Tractor-Widow!"
Edited by CA13414 - 02 Sep 2024 at 9:26am
