Grab Handle
tedholman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tedholman Quote  Post ReplyReply Direct Link To This Post Topic: Grab Handle
    Posted: 02 Jan 2020 at 6:36pm
Is there any place to get a replacement door grab handle for a 8000 series cab door?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 8:35am
Is it broken or just worn? If the padding comes off,they are pretty sharp. I have taken a couple of those off that had bad padding and then buffed off the rest of the padding. Then you can slide a piece of 5/8 heater hose over the strap. You will need to lube the hose to get it over the strap with something, it's a tight fit. I just rivet it back in place and it looks pretty good and is a lot easier on the hands. You could also take the one off of the right door and put it on the left. The right door rarely gets used here.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 11:45am
I ordered one from agco a few years back and it was a piece of bent tubing. I never used it . I been thinking about making mine like Lynn said but have one of the leather belt guys sew two pcs together and slide that over a new SS strap. Could even have it stamped with the AC logo.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 9:02pm
It would look like a farm boy fixed it, but how about a length of serpentine belt? It would be black and hold its shape.?.?.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2020 at 11:19pm
Looks alot like my 88 LaSabre pull strap...but I bet it is NLA too
This page was generated in 0.112 seconds.
