Governor for 301 gas combine to tractor engine.
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Topic: Governor for 301 gas combine to tractor engine.
    Posted: 05 Feb 2025 at 6:03pm
  My 7020 gas passer swap is great but as the experts here suggested it can be better with a tractor governor.
   Can anyone give me an idea of what parts are necessary to swap ? It looks like the parts are mostly external so no major surgery needed.
    Maybe a photo?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 6:27pm
The governor weights inside are different between tractor and combine. You need all the tractor internal and external parts to do this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 8:30pm
Oh darn. I think I'll run it the way it is then.Not that bad to deal with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 9:43pm
It's not a bad job at all. You just need a donor engine for the parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2025 at 2:40pm
ok thanks
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2025 at 12:17am
The difference is how the governor is designed to operate.
The combine power unit is intended to run the combine at a preset constant speed... it has a low-idle position, but when time to operate, it runs at that preset speed, not 'somewhere in-between.
The tractor engine is intended to be variable in it's speed setting... any point between low idle, and full speed.
The combine governor in a tractor application will work, but it will NOT be particularly stable at any point other than full governed speed.  It will be VERY stable at that speed... meaning... a very slight change in load will be responded to.
The variable governor of a tractor allows choosing the setpoint, but in doing so, sacrifices sensitivity and accuracy.
The constant speed governor of a power unit sacrifices adjustability for sensitivity and accuracy.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2025 at 2:04pm
So governor parts from a 190XT’s G2800 301 only?
What about the G2500’s governor parts used in either the 180gas or 190gas ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2025 at 2:12pm
180-190-190XT all the same parts. 180 might have a weaker spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 7:49am
Finding a donor engine may be a challenge nearby.I will start looking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 1:12pm
I would not put up with a combine gov in a tractor! You may not find one close but there has to be plenty in salvage in the states. It can't be that cost prohibitive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 8:25pm
Tomorrow is another week.I will start the search around here first . Any suggestions for possible places to try in the northern states?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 9:44pm
Google or other search engines
