Got the IB running
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Got the IB running
    Posted: 25 Nov 2009 at 7:50pm
This little guy ran great all last year, then one day decided not to start.  I had spark, and gas ran out of the drain on the carb.....so it sat for a year.  Today I had some time to trouble shoot....only thing I could think of was the carb, but it had been rebuilt by the po. Anyway, I pulled it off, which wasn't easy due to an aftermarket manifold that wouldn't allow a box wrench on the back bolt....had to take off the air cleaner, which is a job in itself on an IB.  Anyway, I got the old one off and took one off a locked up donor C and put it on. Fired right up....now what could go wrong with a carb that would cause it to totally fail? I haven't taken it apart yet. I always thought if I had spark and gas these guys would run, but this is was an exception. It wouldn't even pop with a shot of ether...
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 9:13pm
well that is good news you have gotten something to run and here i have something that wont want to run. glad to hear this eldon. you must have something plugged.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 9:17pm
My bet is the float needle stuck in the seat. You'll be able to duplicate that condition when you take the old one apart. It seems the newer needles with the rubber tip are prone to that.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2009 at 9:31pm
or main jet plugged with rust.
bigallis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigallis1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 7:40am
Definately has crap in it and something plugged.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 9:03am
You didn't say whether you re-connected the air cleaner again after you installed the carb off the C. If you didn't, there might be an obstruction in it blocking incoming air. No air, no run. If you did re-install the air cleaner, then it could be a blocked nozzle/ emulsion tube.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 9:18am
This sounds like the story of the blonde who took her new Italian sports car to the mechanic because it wasn't running right.  After about 1/2 hour the mechanic comes out and says it's fixed.  The blonde askes "what was wrong"  The mechanic says "Just crap in the carburetor".  The blonde asks "How often do I have to do that?"
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 9:57am
Hey Eldon,  Don't forget those small jets at the bottom of the carb.  I still remember Pop taking them appart on the Post Office table on newspaper - yes my Mother also ran the Stevenson, MD Post Office - and using parts tag wire to clean them.
Fixed a lot of problems.
In any event you got it running.
Good Luck!
Bill Long
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 10:41am
One more possibility Eldon.  Had a carb professionally built, No Gas.  Carb was clean as a whistle inside.  Ended up  replacing the float with a used one.  Reassembled, installed it and it fired right up.  Apparently the new float was touching the sides of the carb and hanging up not allowing fuel past the needle and seat.  HTH
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 1:00pm
I have similar issues to investigate on my C. I let it sit all summer, now have gas running out the bottom of the carb. I'm betting on a stuck needle valve.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 1:09pm
Since I had gas in the bowl I figured the float and valve were ok. Plugs were dry, so it wasn't getting gas to the cylinders....always had luck with ether in that situation. My guess now is  it must be a plugged jet, which would be weird since it has an in-line filter on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 1:11pm
Dave in cases like yours I have had good luck shutting the fuel off at the tank before starting, then just crack the valve open while running.  Usually the vibration from the engine will jar the float loose. I have a WD that will do that every time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2009 at 2:54pm
Eldon, I'll try that before pulling the carb! Thanks for the tip.
WC, CA, D14, WD45
This page was generated in 0.054 seconds.
