Got the hot…………
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Got the hot…………
    Posted: 23 May 2025 at 6:56pm
Water plumbed to the laundry room. Opted for 3/4 pex, with the pinch clamp style.
100 foot roll was $48.50, the crimper $57.00, don’t remember the cost of the bag of clamps or the 2 pex elbows. The roll is a bit of a challenge to work with when working alone, under a pier & beam house. Just couldn’t get to lay out flat, thus it took a few more feet to do the run.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 7:06pm
PEX is great stuff !!.... YEA, rolling it out STRAIGHT is a bit of a challenge... working in the house on short runs and thru walls is very forgiving... I ran a 3/4 inch header, then 1/2 inch for anything under 30 ft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2025 at 7:34pm
Now the next project to save up for is plumbing & installation of a water softener. Plan on using the existing 3/4 pvc that supplies the cold water to the laundry room, that is where I will put the WS, then run new 3/4 line from the WS to the utility room about 50 ft away. There I will plumb the soft water to the water heater, sinks and showers. Will separate off the outdoor faucets and toilets to supply with unsoftened water. Also a hard water line to the RO at the kitchen sink for drinking and cooking water.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2025 at 10:38pm
Lars- In the morning take the end of your pex roll (usually from the middle, and unwind a hundred feet or so out into the yard.  Park your riding mower on the end, and leave the rest at the far end, out in the sunshine. Pull it tight so it gets 'flatter'.  About lunchtime, pull it tight again.  By midafternoon, it'll be easy to feed through straight- cut off about-how-much you'll need, and pull it through. Wink
This page was generated in 0.484 seconds.
