Got the coil problem fixed...
Dana(Iowa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dana(Iowa) Quote  Post ReplyReply Direct Link To This Post Topic: Got the coil problem fixed...
    Posted: 07 Oct 2011 at 5:09pm
Thanks again for all the pointers on the coil issue I was having on my D14.  Last night I replaced the points, condenser, along with a new internally resisted coil.  It fired right up and purred like a kitten.  Buttoned it all up, and went to pull it out of the pasture where it had died and low and behold the left front tire was flat.  My son went and got my air tank and filled the tire enough that I could limp it back to my shop.  The tube had a hole so we removed the entire wheel/tire and took it in to town to get it fixed.  As I was getting ready to bolt it back on, I noticed the left side of the wide front seemed loose.  That was an understatement!!!  The two bolts that hold the left side of the wide front on were extremly loose!
I think I can safely say this is the first time I was GLAD I had a flat tire!!  It make me shudder to think what might have happened - especially since I had just had the tractor out on the highway a couple days earlier buzzing into town to help a friend move a shed.  If that front end had come competely loose at full throttle in 4 high, it wouldn't have been pretty!
Lesson learned.  I need to periodically inspect these critical connections even on my tractor that hardly gets any use compared to others on this site!
1957 D-14 with loader
1947 Model C (restored)
1947 Model C (unrestored) SOLD!
1972 220
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2011 at 7:39pm
glad you got it going and glad your not a farm accident statistic
This page was generated in 0.093 seconds.
