Got the CA running good!
Larry in OK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Topic: Got the CA running good!
    Posted: 31 Mar 2010 at 9:21pm
Got got my '52 CA going Sunday. Runs strong and everything seems to work like it should (except the @%#% generator so far).  Got a few little things to get squared away and a little tuning to do, it wants to dog out and jump a little in 4th gear, but I'm happy with it so far.
My grandson sure seemed to like it.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 9:30pm
Looks good. Much better than the first time we saw it. Good luck with it, and keep the grandson on it as much as you can. I spent a lot of time on a C with my grandad when I was a little fella. Makes for some good memories later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 9:38pm
I probably scraped and washed off 100lbs or more of crud, grease and mud dauber nests.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 9:39pm
Ahh a pin hitch CA. What's the serial number? I have Dads 51 #669. I have the angle iron cultivator mounts and the front cultiv mount. I also have the 2-14 plow the 6' disc he got for the C, a 5 ft sickle mower and the 2 row cultivator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 9:50pm
Tractor # is CA 11282, the engine was replaced some time in it's life R14620G.
I'm planning on putting a 3 pt. on it. Pin hitch implements are kind of scarce around here and my uncle only had a 2 bottom and a 3 bottom plow with the pin hitch, everything else he had was pull type stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2010 at 9:59pm
Which reminds me, I saw what was either a CA or maybe a small D-series on the way up to Rome GA yesterday. Couldn't tell much about it. It was under a metal carport and had a blue tarp covering most of it. Did notice it had some pretty heavy-duty rear wheel weights. If I finish up in time tomorrow, I might ride back down that way and have a closer look.
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 9:45pm
Larry, looking good. I have a '52 serial #14298. Here is the 3 pt. I put on my pin hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 10:07pm
That's pretty neat. Is that shop built or store bought?
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 10:26pm
Everything is from a Cross Manufactured 3 pt. except for the horizontal cross member holding up the bail, it was home made, I dont' know who made it I bought it from Leon B. It Bolts to the sides of the final drives, works really well. I don't think anyone is making a 3 pt that will bolt right up the pin hitch tractors. I can take some close ups tomorrow if you would like to see it better. Ron
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 11:00pm
I'd appreciate that.
 I've been looking at the ones shown on OKtractors website but I don't have the funds yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 11:22pm
The 3 pt from OK Tractor will work, you'll just have to fabricate a cross member to hang the drawbar bail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in OK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 11:51pm
Thanks for posting those pics Ron. I had to go out and look at the finals on mine to see if it had the bolt holes (It does).  I can see what I'll need to make it work for me.
I've got permission to scrounge my late uncles junk piles, I'll have to see what I can find.
Edited by Larry in OK - 02 Apr 2010 at 11:52pm
