Got me a $500 running driving truck,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Got me a $500 running driving truck,
    Posted: 12 Jul 2018 at 3:50pm
Pulled onto the trailer starts and drives!!
Got the frame shortened and a used grain box to install on it.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 4:08pm
Lookin good... no more gas thieves with that rig. Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 4:21pm
Nope, LP. Dang truck has at least $500 in newer rubber on it. old 366 starts right up.
14' grain side, looks to be a old Parkhurst body, solid except typical rotted floor, came with the scissor hoist and pump just have to get a PTO for a AT542.
Oh the truck has an Auto in it!! Couple small details, exhaust leak p/s leak and have already replaced rear disc calipers and pads as well wheel seals. Got all new cab lights, old ones ozone crumbling, still have to plug the six bolt holes in cab roof from Reefer walk plate they removed. Did get pivot set up and rear bumper built, taillights are working.
Edited by DMiller - 12 Jul 2018 at 4:25pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 6:45pm
Just curious.  Do you gotta put a hoist on it?  Will you build it or look for a used one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 6:48pm
Bed came with a hoist under it, scissor style and pump included.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 7:07pm
Grand theft auto!!!!
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 8:00pm
Want your money back? That'd make a fine dump truck around here
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 8:28pm
Gonna be a Fine Farm wagon round here!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 8:33pm
Is a 86, parts are becoming more scarce than I could imagine. Mufflers are rotted so went to order a pair, GM no longer shows a stock number, NAPA said try a muffler shop, got a pair of generics from CARQUEST. P/S seal kit also from CARQUEST as GM said No Longer Available. Brakes, calipers, rotors all available aftermarket yet had to convert later model rear caliper hoses to fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 8:54pm
glass packs!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2018 at 9:05pm
I had a '79 like that with an Allison 545 auto. Had 2 speed axle and air brakes. No problem with the PTO. Put trans into drive to engage the PTO and then shift back into neutral. Step on the gas to raise the hoist. Let your foot off the gas and the hoist stop raising-cool I thought until the load was half off and the hoist started going up by itself. Quick scramble to put the hoist lever into hold position.
