Got me a $500 running driving truck, |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34123 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Jul 2018 at 3:50pm |
Pulled onto the trailer starts and drives!!
Got the frame shortened and a used grain box to install on it. |
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34351 |
Lookin good... no more gas thieves with that rig.
Nope, LP. Dang truck has at least $500 in newer rubber on it. old 366 starts right up.
14' grain side, looks to be a old Parkhurst body, solid except typical rotted floor, came with the scissor hoist and pump just have to get a PTO for a AT542. Oh the truck has an Auto in it!! Couple small details, exhaust leak p/s leak and have already replaced rear disc calipers and pads as well wheel seals. Got all new cab lights, old ones ozone crumbling, still have to plug the six bolt holes in cab roof from Reefer walk plate they removed. Did get pivot set up and rear bumper built, taillights are working. Edited by DMiller - 12 Jul 2018 at 4:25pm |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
Just curious. Do you gotta put a hoist on it? Will you build it or look for a used one?
Bed came with a hoist under it, scissor style and pump included.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8646 |
Grand theft auto!!!!
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5100 |
Want your money back? That'd make a fine dump truck around here
Gonna be a Fine Farm wagon round here!!
Is a 86, parts are becoming more scarce than I could imagine. Mufflers are rotted so went to order a pair, GM no longer shows a stock number, NAPA said try a muffler shop, got a pair of generics from CARQUEST. P/S seal kit also from CARQUEST as GM said No Longer Available. Brakes, calipers, rotors all available aftermarket yet had to convert later model rear caliper hoses to fit.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
glass packs!
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4543 |
I had a '79 like that with an Allison 545 auto. Had 2 speed axle and air brakes. No problem with the PTO. Put trans into drive to engage the PTO and then shift back into neutral. Step on the gas to raise the hoist. Let your foot off the gas and the hoist stop raising-cool I thought until the load was half off and the hoist started going up by itself. Quick scramble to put the hoist lever into hold position.
