Good old D14 added to the pile
 Post Reply Post Reply Page  <1 234
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2025 at 11:20am
Dave,
 That's a great suggestion. Wonder if it would ride up any? I like the concept.
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2025 at 4:38pm
Guys,
 Still plowing snow over here. No real large amount, maybe 3-4 inches last night. The D14 started ok but not as well as the CA. It got the job done again today. Temps are around 25 deg F.
Stay warm out there in Orange Land!
Chris and Cheryl
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 2:18pm
It started snow here in Ohio around 2:00pm
Saturday so more is on it way. better get it fueled and be ready
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2025 at 9:00pm
tadams, Folks,
Thanks for the warning!
We have been hanging in the shop working a little on the sliding doors.
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 7:11pm
Guys,
Plowing today I hear this growling sound in the under hood area.
 Kept plowing. the noise reduced but did not go away. When I shut off the tractor it sounded like the starter was trying to run but not engaged? tapped the solenoid and it stopped. Charged the battery and after cool down it started up ok. Humm Maybe bad started or solenoid??
yea its winter but supposed to warm this week?
 Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2025 at 8:06pm
We have only had light snow but it’s cold in my neck of VA. 11 last night, got up to 24. 17 now, down to 12 tonight. Supposed to be cold through Saturday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 5:10am
Sounds like the solenoid was hanging in. check for poor connections, too.  pull the inspection cover on the back end of starter and check for heat damage on the brushes.  6 volt, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2025 at 7:03pm
Dave,
Yes 6 volt. I did take the solenoid apart and clean it, but that doesn't mean its working. It did start after the battery was charged. May have to pull the starter if it keeps acting up.
Thanks for the support too.
Maybe warmer temps for a couple days to give us a short break from snow.
 Chris and Cheryl
Edited by Sugarmaker - 16 Dec 2025 at 7:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 6:35pm
Guys,
The D14 started hard out in the cold mini shop. Even with the battery charger on for a day. I moved it to the warm shop after about 10 min of running. I had the gas shut off but I saw some gas on the exterior of the carb. So I thought maybe it was flooded prior to trying the cold start. Anyway after being in the shop it started easily each time I tried it. Starter sounded good, solenoid preformed as needed. So I called Brenda at Sandy Lake several reasons. I ordered a premium carb kit for the Marvel  Schebler TSX 670 carb. Also a replacement sediment bowl assembly. The carb doesn't look like it's been off for years. A clean up probably wont hurt that a bit.
The replacement sediment bowl may actually shut off the gas to the carb when needed.
While talking with Brenda I mentioned that the tractor engine governor was "hunting" during initial running. She asked if there was a spring on the governor rod behind the carb. I looked and yes there was a spring but the hook portion was so weak from corrosion it had come off the manifold bolt. So I ordered a new springs also. I did try to put the spring back on and it did actually start better, and did not have rpm's going up and down.
I think the D14 just wants to stay in the much warmer shop!:)
 Chris and Cheryl
Edited by Sugarmaker - 18 Dec 2025 at 6:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2026 at 8:36pm
Allis Folks,
The D14 reluctantly started today. Outside temp is around 20 deg F. same temp where the D14 is stored with the other tractors.
It worked well to plow the U shaped drive around the shop. Some of the piles are getting 4 foot or more in height. The high lift and plow work great to push snow over the top of them.
The engine did run better with the small spring in place on the governor to carb rod.
 Chris and Cheryl
Edited by Sugarmaker - 01 Jan 2026 at 8:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 11:34am
Guys,
A question on the D14 brakes. The right brake locks up when I just touch the pedal. Anyone want to speculate as to what the issue might be with the brakes? I have not started to look at the problem. When the brake pedal is released I do not hear or feel any drag or noise coming from that area of the rear end of the tractor. Something is not right.
Chris and Cheryl
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 3:17pm
Guys,
Chris and Cheryl
A cracked shoe or lining can cause that...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2026 at 8:51pm
Dave, folks,
That is probably the cause. Have to pull the trumpet and rear axle to get the shoes off?
How do I get myself into these projects? Any way to visually inspect these shoes? Sounds like a project.
Chris and Cheryl
