Good old D14 added to the pile |
Page <123 |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8592 |
Posted: 05 Dec 2023 at 11:26am |
Ted,
Thanks! I dont have a plan to restore the D14. Unless I really run out of things to do later in life? The D14 worked well plowing snow in our first big storm! Regards, Chris and Cheryl
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11080 |
Posted: 05 Dec 2023 at 12:35pm |
You should have made the new smaller shop bigger
Sugarmaker
Posted: 06 Dec 2023 at 8:33pm |
Tadams, Cost and land dimensions issues were a couple of my restrictions. Yes they are never big enough! Very glad to off load the big shop. I do have too many big orange toys! Here is the 32 in the big shop living room, ![]() Just worked on a small whitetail deer using the jib crane. Son Adam is living in the loft for the holidays, and seems real comfortable: We have been making maple confections in the shop kitchen: The Ford F250 sets in the bay with the two post lift. The Allis CA sets in pieces waiting for a "clean refurb, and paint"! Regards, Chris and Cheryl |
Sugarmaker
Thanks(1)
Posted: 26 Oct 2025 at 9:11pm |
Allis folks,
Well The D14 does not get used much or even started often during the summer. In fact I did not even take the chains off the rear tires! So a year ago or longer I took the starter off and cleaned and checked it and the tractor seemed to start better, well that did not last. The D14 has not been starting good at all just clicks and rolling over for a couple revs then stopping. I was at a friend's house and talking with him about this. He mentioned that the Solenoid could be refurbished. I felt that the solenoid could be suspect. So Today I took it apart. Had never done this. What I found was very corroded and burnt contacts. I disassembled the components, sandblasted them and reassembled, new pop rivets in the corners. Installed the solenoid back on the starter. The tractor started very well on 6 volts. The cleaning of these internal electrical components acts like it really helped. On to the generator and charging system next. Regards, Chris and Cheryl
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3112 |
Posted: 27 Oct 2025 at 5:10am |
Good job Chris! Love the D series , but I just send electrical stuff to NJ Steve. I hit the EZ button.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5259 |
Posted: 27 Oct 2025 at 8:51pm |
Chris I need to get back to work on my 59 D14. Added PS last year shortly after I purchased it. Surprisingly, I enjoyed rebuilding the front support and man do I like having PS! Mine being a 59, is a 12v factory tractor, our dads 57 was 6v and no PS. It always started well on 6v but I'm glad mine is 12v for better winter starting. I was getting ready to prep and paint it when I stopped working on it to build new fence at the farm for my wife's sheep. Hay season started, remodeling of rental property.....well you get the picture.
Rob
AC WD45
Joined: 28 Sep 2009 Location: Mid Michigan Points: 2077 |
Posted: 28 Oct 2025 at 5:18am |
That dozer blade is really hard to find when you want one.
German Shepherd dad
Sugarmaker
Posted: 28 Oct 2025 at 6:51pm |
Allis guys,
Thanks for the support! Yea would like power steering on this tractor also. Would really make it a joy to operate for any one. I horse it around and do minimal loader work. The blade and tractor were purchased together along with the chains. The idea was to have a snow plow tractor. Well it has worked very well for that. Making small improvements in the systems will be good when I need the tractor this winter. It may be a mild winter and that's fine if I never have to use the D14 and blade this season! I ordered a new Voltage regulator from Sandy Lake Implement today. Still did not have any improvement in the charging system after testing the generator. It motored and the field test was ok. So we are still at 6 volt on this system. It has a almost new battery. I have thought about changing to 12 volt. That would be another $400 at least, and sometime rewiring it also. We will see if this new voltage regulator gets us charging again. I am going to clean up the contacts on the old regulator and test it again too. These old tractors are sometimes a pain to work on. But satisfying when things function and work well! This D14 has had a very good life. It has had a engine overhaul before I purchased it. I am only the second owner and it was sold and lived within 30 miles of me. I have seen many that have been used and abused. This one may not have shiny paint but it is a good old Allis tractor! Regards, Chris and Cheryl
Edited by Sugarmaker - 28 Oct 2025 at 7:18pm |
Joined: 11 Sep 2009 Location: illinois Points: 88864 |
Posted: 28 Oct 2025 at 9:39pm |
Chris, the regulator and battery work together to hold the CHARGE down to about 7 volts... If you take the wires off the generator and then start the engine and spin, the GENERATOR will put out about 15v on a 6 v generator and about 30v on a 12 v generator.. Its the BATTERY that drags it back down to 7v... with the help of the regulator.. you can test this way to see if the generator is in good shape.. or the regulator is the problem..
Sugarmaker
Posted: 29 Oct 2025 at 6:42pm |
Steve, folks,
Thanks, yes I am going to do some more checking on the existing 6 volt voltage regulator. The grounding areas (mounting bracket) and all the contacts on the regulator were very corroded. So the bracket and grounding needed cleaned up even if this regulator is not good. Some good info on testing the generator and the regulators on line. I get an hour or so each day to play with the D14 in the shop. No snow here yet but we have had several good frosts. Regards, Chris and Cheryl
Sugarmaker
Posted: 30 Oct 2025 at 7:19pm |
Allis folks,
John and I spent the day playing with the electrical systems on the D14. Reassembled the voltage regulator after sanding the points and cleaning them. All looked good. Checked ground from field terminal to body of regulator frame. All good. Cleaned all the terminals and hardware including the contacts ends of the wires. Green corrosion was all over these areas. Voltage regulator all rebuilt:) Then we fired up the tractor and we had positive movement of the Amp meter, checked the battery with the old volt meter, and we had a good charge of about 8 volts when revved up a little! So my new regulator that I just ordered may set on the shelf for a while? We moved to the wiring for the lights. Nothing seemed to function. The small junction contact terminals behind the grill were green with corrosion. So not that we wanted too, but we removed the terminal for the lights and cleaned it up too! Finally we had to remove the light switch from the dash. It was a mess! Yep lots of corrosion on the contacts and wire ends not allowing those very tiny electrons to pass to the front or rear of the tractor. Also the switch did not have continuity across the light switch terminals. John took the switch to the bench and opened it up. More corrosion! He cleaned all the contacts and bent the little tabs back to hold the light switch assembly together. A little lubrication on the stem and it was as good as new! When re-installed the switch provided power to the one headlight that works! More work to do to get the rear lights functioning someday? It was a good day in the shop at about 66 deg from the floor heat! Nice! Getting closer to being ready for the snow. I think the carb on this tractor needs looked at. It does not start as easily as the CA? Regards, Chris and Cheryl Edited by Sugarmaker - 30 Oct 2025 at 7:28pm |
Sugarmaker
Posted: 03 Nov 2025 at 5:58pm |
Allis folks,
One of my 4 projects for the day. Noodling out the high lift support arms on this loader. So first they were missing. Not surprising. I got some black pipe that fits the socket well. drilled a hole for the pivot. I ordered a couple 3/4 inch dia turn buckles. The idea is to weld one end of the turnbuckle on to this pipe and have some adjustment when its time to remount the loader to the tractor. The other end of the turn buckles would have a short piece of angle iron welded on to set in the dirt. Ok I don't take this off very often but maybe I would if these work. I really have only been using the D14 as the snow plow unit for last year. But we did take it to a plow day and had fun with it and the Allis 2 bottom mounted plows. So we will see if this works?? Concept:Extend turn buckle and raise the lift arms to get it attached. Also making them a little longer to drive the front through. Was very tight fit before when propped up with boards. I am also going to try to fab some ends for the blade to make it hold snow a little better?? These ends would be the height of the blade and stick out about 14 inches in front of the blade. All sounds good on paper. My plans usually go south pretty quick!:) I did a cold start on the D14 today and it did eventually start. But I think I flooded it. I forgot to turn the gas off when it was shut down. Regards, Chris and Cheryl
Edited by Sugarmaker - 03 Nov 2025 at 6:10pm |
Sugarmaker
Posted: 04 Nov 2025 at 6:54pm |
garden_guy
Joined: 05 Jul 2013 Location: Illinois Points: 1163 |
Posted: 04 Nov 2025 at 8:20pm |
Glad to see you're still at it sugarmaker! Wish I had a shop with a concrete floor, this working on a dirt floor is the pits!
Sugarmaker
Posted: 06 Nov 2025 at 4:59pm |
Sugarmaker
Posted: 07 Nov 2025 at 10:31am |
Allis folks,
I have the wing design layed out for the ends of the push blade. Need to go to town to get oxygen to cut out the shapes. This will make it into a poor mans box blade. The end pieces may just be welded in place direct to the blade or may be bolted on so that they could be removed?? We will see how the end pieces fit when cut out and cleaned up. They are about 21 inches high, the height of the blade, about a 1/2 inch off the ground on the bottom. (room for a shoe if needed). The distance out from the blade is about 16 inches. (that's all the material that I had to make these two box ends). Regards, Chris and Cheryl
Edited by Sugarmaker - 07 Nov 2025 at 10:38am |
Steve A
Posted: 07 Nov 2025 at 5:52pm |
I'd bolt them. That way if you ever modify it to angle you can easily remove one side.
Sugarmaker
Posted: 14 Nov 2025 at 8:27pm |
Steve A, folks,
I touched these end plates out this morning. Was good to do some oxy/act cutting. Yes I plan to bolt these wings on to the ends of the blade. Good suggestion. We don't have any snow yet. Maybe wont need this plow tractor this year?? I drilled 4 holes in each side for 3/8 bolts. My helper, taking a break. Regards, Chris and Cheryl
Edited by Sugarmaker - 14 Nov 2025 at 8:29pm |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4170 |
Posted: 16 Nov 2025 at 6:53am |
Love that last picture Chris! Box blade ends look good too.
tadams(OH)
Posted: 18 Nov 2025 at 2:34pm |
Is the puppy waiting for a ride ?
Sugarmaker
Posted: 19 Nov 2025 at 8:03pm |
tadams,
Duke found this bottom shelf to be one of his "caves" on day one. He is going to out grow it soon. Regards, Chris and Cheryl
Steve A
Posted: 24 Nov 2025 at 11:04pm |
I did that on a snowplow blade for a Farmall A to prevent trail off. I also had to add a piece of angle iron at a 45 deg from about the midpoint in the "wing" to the blade so that the wing wouldn't bend.
Sugarmaker
Posted: Yesterday at 7:32pm |
Steve, Folks,
Thanks for the tip on stiffening the wings on the snow plow. We may get a chance to try it out as the weather guys are predicting some snow after Thanksgiving. Regards, Chris and Cheryl
tadams(OH)
Posted: 6 hours 40 minutes ago at 2:03pm |
Happy Thanksgiving Sugarmaker
Page <123 |
