Glow plug, manifold heater amps? |
E7018
Topic: Glow plug, manifold heater amps?Posted: 14 Dec 2010 at 6:27pm |
On a 301 engine, how many amps or watts is a glow plug intake manifold heater? I need a starter solenoid switch, right? Not a 40 amp automotive relay? The inch square ones.
Steve M C/IL
Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Posted: 15 Dec 2010 at 12:31am |
All the manifold heaters were operated by a solinoid switch.It looks like a starter solinoid for a old Ford but I don't know if it's just that.Don't know the amps but it uses cables not wires.
Edited by Steve M C/IL - 15 Dec 2010 at 9:55am |
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 15 Dec 2010 at 5:57am |
I was able to find a solenoid at a dealer for my 185 when it needed one. I used a solenoid from a garden tractor for a forklift (same heater) when it needed one, worked good. Ford's a good bet, look for single pull in terminal.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 15 Dec 2010 at 6:44am |
My A-C diesel forklift has a Ford starter solenoid supplying the power.You can buy high current(60Amp) push button switches that should work but cost more $$ !
I've thought about having a second battery just for the glowplug...another winter project !
Roddo
Joined: 16 Jul 2010 Location: Brant, Ontario Points: 466 |
Posted: 15 Dec 2010 at 9:41am |
The Ford starter solenoid sounds like a good idea. The 7.3 diesel used basically the same solenoid for it glow plug controller.
Bruce Nelson
Joined: 17 Sep 2009 Location: Centuria, WI Points: 137 |
Posted: 15 Dec 2010 at 9:56am |
I just tested the heater on my 180 and found that it draws 51 amps. |
Brian Jasper co. Ia
Posted: 15 Dec 2010 at 12:10pm |
The glow plug relay on a 7.3L Ford looks similar, but they are not the same as the old fender mounted starter relay. The difference is they don't ground through the bracket, and if you buy them from Ford they're over $100.
Roddo
Posted: 15 Dec 2010 at 1:51pm |
As soon as I hit post I knew you'd chime in. Edited by Roddo - 15 Dec 2010 at 1:51pm |
jaybmiller
Posted: 15 Dec 2010 at 1:55pm |
Same 'Ford ungrounded' relay is only $9.98 at the local Princess Auto, less than 10% of the Ford dealer's price !
