Glencoe vs
Message Reverse Sort Order
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: Glencoe vs
    Posted: 20 Dec 2019 at 9:11am
Originally posted by soybreedingboy77 soybreedingboy77 wrote:
Newest would be the 7400
Newer would be green with black blades vs white with orange blades
Thanks for that info!
soybreedingboy77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2019 at 7:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2019 at 9:57am
Originally posted by victoryallis victoryallis wrote:
Newer Glencoe have more clearance to pass trash than the older ones. Older ones aren’t hard to plug
What kind of time frame is "older"  vs "newer"?
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote soybreedingboy77 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 7:24pm
The Glencoe Soil Saver is heavier compared to the John Deere of the same vintage. Glencoe frames are solid steed vs tubeular for the Deere. Everyone in our area used 3” twisted points on the Deere 714, the 4” twisted points would not stay in the ground. The Glencoe all used the 4” twist points.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2019 at 7:53am
Thank you Never green.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2019 at 1:09pm
99% sure yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2019 at 12:10pm
I would consider a sunflower. Always have heard good things. The only reason I asked specifically about these 2 brands is there are both of them at 1 location.
Is that reset the case for both of the Deere models?
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2019 at 10:30am
have you looked at or considered a Sunflower? I like the one I have. and Sunflower is under the AGCO umbrella...
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2019 at 8:36am
The Deere has a trip auto reset for their shanks like a plow so you get no bounce in tough conditions, true depth its called.
One of the few things I brag about 'sittin on a john"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2019 at 7:31am
Hey all. Looking for a little advice. “If” money were not an issue, what’s the comparison between a Glencoe soil saver versus a Deere 714 and a Deere 2700. The 2700 is obviously newer, but stick to function and bang for buck. Are Glencoe parts still available?
This page was generated in 0.168 seconds.
