Gleaner windshields
SamT-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SamT-Ga Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner windshields
    Posted: 28 Mar 2024 at 2:34pm
What kind of job is it to take cab windshield out of 73 L combine and put in K2. They are same part number, K2 is busted, L is good, just 50 yrs old.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 6:24pm
The rubber that holds it in has a parting line in the middle. One side is in a groove tucked under the other side. Start where the ends are,normally at the bottom, with a flat screw driver and pop one side out from under the other side. Do that all the way around and the windshield will come out. Its easy to see how it works when you get it started opening up. Better get some straps around the windshied to hold it until you get control of it or you might wind up with a bunch of little pieces. Dont ask me how i know
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 9:09pm
My auto glass guy would come here and do it for a fee. He's good.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2024 at 9:17pm
Probably the same as windshield of 70xx's. Maybe practice with the broken one.
Leon B Mo
Michagman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michagman Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2024 at 4:02pm
We swapped a side window around on a Year-a-Round cab and it wasn't too bad.  It sure was nice to be able to put its frame on the workbench.  I imagine a combine windshield would be a bit trickier.  You may need to be careful with that 50 year old window molding, ours wasn't that old and it just crumbled.  The new molding was much easier to install at least.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 5:41am
Good description. It can be done solo, but it’s easier with two people. I’ll add some comments.
First thing- a bucket of soapy water & sponge or even a can of penetrating spray lubricant helps soften up & relax older rubber gasket. Next, a newer edged flat screwdriver can aid in “opening-up”~ unzipping gasket seal.
When installing windshield, place gasket around metal frame first & then push windshield into gasket. Once windshield /gasket is “slotted together”, use an older used “dull-edged” screwdriver for “re-zipping” gasket into locked position. Again soapy water/penetrating lubricant helps the seal zipping up process. With lubricant applied & once zipper seal gets started, one continuous stroke of the older screwdriver to seal will pop/lock gasket seal into position.
Edited by AC7060IL - 30 Mar 2024 at 6:12am
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2024 at 6:22am
Get a can of silicon spray lube.  It will help bring some flexibility back to the rubber.
Life is simpler when you plow around the stump.
