Gleaner R50 light package question
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner R50 light package question
    Posted: 03 Aug 2016 at 11:32am
Does anybody have sales literature that would show the maximum lights available for an R50 Deutz?
Thanks!
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 7:50pm
Two up in the roof by the duetz decal, four flood just below those, two at bottom of cab for the head, one by door pointing to auger for unloading and there was an optional spot light. I think some late models had one or two lights on the back end
8070FWA,7080 BlackBelly, 7045,2 200s,D19,D17,G, WD,45,UC,7 AC mowers and lots more!
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!"
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2016 at 7:09am
ok thanks, i had a feeling our's had been customized slightly.  the 4 floods are mounted on a piece of square tube on ours extending them beyond the edge of the cab a ways.  Our plan is to replace everything except the 2 under the deutz stickers with led lights and add 2 additional lights at the rear (under the sheet metal at the corners as back up lights.  I will post pictures as I go.  These are the lights I will be using since I can buy them for a considerable discount through work.
http://www.buyersproducts.com/electrical-lighting/utility-light/work-utility-lights/oval-clear-led-flood-light-12-24v/5209/
