gleaner power fold ladder????
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Topic: gleaner power fold ladder????
    Posted: 25 May 2012 at 9:00am
i just bought an 84 L3 and would like to build or put on a power fold ladder.
thoughts would be- add the factory setup used if anybody has one.
or
use a couple tiny cyl i have from other sprayers and engineer this to plum into the reel height port for use in corn
does anybody have a used system sitting on a scrap machine?
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
Dale-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 9:08am
The newer gleaners used a electric actuator for a ladder raise, two electric wires are a lot easier to run then hydraulic hoses.  I think new actuators are around $400-450
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 9:21am
dale- mind if i give you a call?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 9:22am
No Problem.  800-996-2937 office or 740-505-0227 Cell
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 11:43am
I think the factory power fold was one electic actuator. The switch was down by the header height control.
ryan
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 12:46pm
We had a Gleaner R62, and it did not have the ladder lift.  I wanted to put one on but never did.  The ones I seen used an electric actuator.
I just bought a new seed tender cart and it uses an electric actuator, but it's an electric pump and a small hyd cylinder all self contained unit to raise the auger.  I can look at it and get you the brand and model, etc if it's something that intrests you, just send a PM.
I'm sure they are both pretty spendy items.  I wonder how a  cheap small light duity electric winch would work from an ATV or something with a little fabrication.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 12:52pm
Surplus Center in Lincoln, Ne has actuators, maybe something that would work.
Allis Express participant
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2012 at 10:17pm
I bought a small 12V wench, mounted on grain bin. Won't win a beauty contest, but does the job.    MACK
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2012 at 7:36am
My neighbor threw a new one for a dish antenna in the back of my van, I haven't even looked at it, don't know what the voltage is for it. I guess I will have to open the box and have a look at it.
Dusty
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 10:31pm
I am with Mack.  Those cheapo $50 winches can do a lot. One of our L2s had the manual/cable engage for the unloading auger. The cable broke, I tried to repair it, broke it again. AGCO wanted $96 for the cable.  I put a $50 HF winch in its place, and swapped the belt to the other side of the idler, now I goose the button, auger starts, push the other button, it shuts off. Aint exactly factory pretty, but it works.
jjpetrich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjpetrich Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 7:40am
It would be best to go electric then with the ladder down to make sure that a spacer is under the cylinder so that if someone steps on it it doest break,  been seeing that alot on the s77's.
On the farm wd,wd45,180,200,7020,8010,8050,f,L2,2 b engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 7:54am
Why don't you just modify the ladder so it doesn't need to be folded up all the time?? You'll soon find out there are times you simply need to get in and out of the cab quickly and often, and there you go....wait for the d#$% ladder to go down and back up.....and then, when the electric motor fails, you spend more $$$$ to keep it working.
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2012 at 8:31am
i guess you have a 4 row head,so just open up the field with the ladder up then leave it down the rest of the time
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 6:50am
The ladder on my R52 is aweful heavy to lift. Wish it had electric lift. What would the modification look like Dr?
I only fold it up when I store the combine because of space issues and because I left the ladder down on my L2 once and hooked it with another piece of equipment Unhappy
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 8:07am
You're taxing my memory, but I think all we did was remove the rubber stops to allow the ladder to swing in closer to the tire. I think we had to trim off some steel in the stop area too. Yes, it makes the climbing angle a little harder, but the ladder sticks waaaaaay out farther than it really needs to be knocking down the next row of corn.
Edited by DrAllis - 18 Jul 2019 at 8:13am
farmboy520 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2019 at 3:11pm
Dad took and cut the ladder on an F we had and welded it back with less of an angle. It made it close to the tire but didn't have to raise it all the time.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 6:56am
I just want my ladder to fold out of the way so I don't ever hook it again like I did on my L2. The L2 ladder must be half the weight of the R52. I can barely lift it on the R52.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 7:10am
I will take a picture tonight of my R62 ladder. It has the power fold
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 8:47pm
This might be EXACTLY why the previous owner of our F2 tapped into the "reel" lift circuit for his/now our ladder lift ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 8:51pm
Clint, just to verify, just what  corn head are you running on your "new to you" machine?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 11:29pm
My 860 cotton stripper (K2 chassis) has a rope on the ladder and a latch up top. Just pull it up, or let it down manually. No motors to fail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2019 at 7:24am
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2019 at 12:43pm
IMO call around to a salvage yard and get the OEM setup. affordable, warm fuzzy feeling of OEM components. :)
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2019 at 6:12pm
Mind posting a picture of it if you get the chance?
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2019 at 10:08pm
The N6 had two switches. One in the cab and a second one under the tin work on the left side.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 6:51am
I used to easily pull up the ladder on the old E. It was light and the L2 is relatively easy too but the R52 is a much heavier ladder and I have a heck of a time to get it lifted. I really only need to lift it when I store it so folding it up from the ground is what I need most. I do have an old satellite dish that I put a new actuator doohicky on just before we quit using it and it looks an awful lot like the pics above but it's been standing out in the elements with trees completely covering it up since 2002. Well....... my need might not outweigh the expense and trouble.
Edited by Lonn - 20 Aug 2019 at 6:52am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmboy520 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2019 at 11:03am
My R62 has 2 switches also. There is 1 in the cab and another by the base of the unloading auger.
