Gleaner N5 transmission lube pressure sending unit |
Post Reply |
AC 426 power
Orange Level Access Joined: 01 May 2012 Location: Ohio Points: 512 |
Posted: 05 Nov 2017 at 1:53pm |
Where is it located? Thanks.
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3242 |
locate the pump on the main transmission , not the hydro. There is an external line and pump. The sender is low pressure and will be at the terminal of about the only wire going to the main transmission beside the speed sensor. It will only go off when one is traveling forward.
AC 426 power
Alright found it, now does the transmission feed off a different oil supply from the main hydraulic system? Or does it get it's oil from the Resevoir tank in the back?
Lynn Marshall
Orange Level Access Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2152 |
The gear transmission is self contained and just coupled to the hydro. It has its own oil and doesn't share any oil with the rest of the combine. It has a check plug on the side and uses a transmission, hydraulic fluid,not red oil and not an 80\90 weight. It has its own pump to supply oil to critical bearings and bushings.
orangereborn
Orange Level Joined: 12 Sep 2009 Location: NW WI Points: 1403 |
Transmission oil pressure light stays on. Oil level is okay. Disconnected the wire from the sender and still stays on. The wire from the transmission switch to the connection outside the cab not grounded. Lead going into the cab not Grounded...Removed the transmission switch and no continuity. This is a grounding switch Or am I missing something? Thanks. Dale
Orange Level Access Joined: 12 Sep 2009 Points: 19560 |
Transmission has to be spinning to put out the light. |
troym
Bronze Level Joined: 21 Jan 2015 Location: minnesota Points: 129 |
switch is normally open, so ground wire with key switch on if light goes out then wiring and module are ok. maybe sender or screen in transmission restricted.
Post Reply | |
