Gleaner k concave bar
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner k concave bar
    Posted: 01 Nov 2020 at 7:43pm
anyone know where I can buy some new or know dimensions and make my own out of channel iron? Thanks.
Would f series be the same just a little longer being an f has a bigger throat?
Thanks
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2020 at 8:06pm
AGCO dealer has them available. I don't remember the price, but it was reasonable. F bars are the same size material, but longer for the wider cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2020 at 8:11pm
Channel concaves are cheap enough at AGCO. there used to be some available aftermarket. Time you fiddle with drilling holes in the right places to "make your own" you'd be ahead to buy em.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2020 at 8:19pm
Ok. Thanks I was thinking of getting f concave bars from agri kits.com they are in New York and can have them in 3 days . Of course I would have to cut them down. I will call albert at zeiglers tomorrow to see how quick he can get them.
Thanks.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2020 at 8:26pm
I would say Albert has them in stock.        MACK
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 5:49pm
Are the concave bar bolts proprietary to Agco, or is there another outlet for the square headed bolts ? Seems like the heads are "offset" to the center of the bolt??
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2020 at 9:52pm
Weld nuts to concave, then screw regular bolts in from bottom.         MACK
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2020 at 4:31am
McMaster-Carr has square head bolts, grades 2, 5 and 8.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2020 at 4:34am
If a person does this, they would want to make sure not to use too long a bolt, or it would hit the cylinder bars.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2020 at 7:20pm
I ordered new concaves and bolts from Albert at zieglers
Thanks cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2020 at 6:23pm
Thanks for the update, can/will you verify if the square headed bolts are "off set" to the bolt?  It's been several years since I messed with them, but seems like they were "odd" Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2020 at 7:09pm
Ones I had were normal. Offset was hole in bar to make head unable to turn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 5:47pm
Squared head bolts are normal. Holes in concave bars are offset so heads don't turn when you tighten up nut.
Thanks cory
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:06pm
Thanks for the reply, I knew that there was something off center Wink. How many bars are you putting in ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:14pm
Holes are offset to be installed to keep the front edge from peeling away from the floor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:40pm
Thanks Doc, we always thought it was for the squared heads to "seat" on . Does it matter if the holes are fore ward or rearward ?
Edited by FREEDGUY - 07 Nov 2020 at 8:43pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:50pm
Holes forward  so material don't start under concave.             MACK
