gleaner head on D17 issue
CTALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTALLIS Quote  Post ReplyReply Direct Link To This Post Topic: gleaner head on D17 issue
    Posted: 30 May 2024 at 2:52pm
put a gleaner head on my D17 and now my push rods are about an inch to short.
Anyone out there have longer roads or know if I have another problem.
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2024 at 3:21pm
Gleaner models "E" or "E-3" has the same HEIGHT head as any legit D-17 and the same length pushrods. Sooo your D-17 must have had a WC/WD head on it by someone which is about an inch shorter. Head bolts are different too.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 5:29am
Pushrods are the same on all the engines.  The only difference in valve train from tall to short head was the rocker stands.  You need the tall head stands which are shorter.  Anything from a WD45 and newer will work.  Like Dr said, you'll also need the tall head bolts as well as the shorter valve cover.
AaronSEIA
