Gleaner F variable speed
BigJon1_WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigJon1_WI Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner F variable speed
    Posted: 05 May 2023 at 11:49am
Hi all. I need some guidance on the variable speed on the Gleaner F. The variable speed pulley is rubbing on the inside bracket that holds the pulley assembly. What's the correct way to adjust it so that it's actually functioning properly?
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 6:26pm
Did you check your bearings?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2023 at 9:14pm
Sounds like you have a bearing out letting shaft move to right side.                           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigJon1_WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 6:11pm
Sorry for the delayed return. The bearing on the right side out and shifted. I guess the other question is how do you set up the linked on the variable speed pulley? This thing has a ton of sketchy fixes and adjustments on it, so I figure it's better to just check them before I break something else.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2023 at 9:15pm
Run VS to hi side.Adjust 5/8 cross bolt to where there is .120 clearance between top two pullies in bottom. Next run to low speed. Should be .120 clearance between lower two pullies at bottom. If not, pull the top shaft back as you rotate the shafts until you have the clearance at lower two pullies. If shafts and pullies are worn, this adjustment will not work out. Run VS to mid range. Measure top set of pullies front and back width. They should measure near the same. Do same to lower set.                   MACK
