Gleaner engine into a 8050?
977.3Ford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner engine into a 8050?
    Posted: 18 Aug 2025 at 1:39pm
Was running the square baler with my 8050 yesterday when it decided it wanted a nice crankshaft inspection hole in the block. Needless to say i'm now on the hunt for a new engine to get it going fairly quick. I'd like to swap in a 8.3 Cummins, but after pricing some things thats not in the cards for a while.
As i figured i'm not finding too many tractor engines, but tons of combine engines. From reading around i know i'll have to tear both engines down pretty far to get everything swapped around, but are there any specific years or models to look for?
Jimmy
1982 8050 Powershift
1982 6080
1992 R52 Gleaner
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 1:43pm
1982 OR NEWER to have your same fuel injection system. A model N-5 or R-5 would be my choice.  A fairly easy swap. Leave the front plate on the combine engine and make a couple of bolt-on angle irons to mate with the side frames.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 977.3Ford Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2025 at 7:57pm
Well that should make it better than i was expecting then. I found an engine out of a '83 N6 for a good deal locally. My injectors and pump have less than 150 hours on them so at least i'll be able to re-use them.
Jimmy
1982 6080
1992 R52 Gleaner
This page was generated in 0.146 seconds.
