GLEANER E-3 owners manual
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: GLEANER E-3 owners manual
    Posted: 24 Dec 2022 at 4:36pm
Looking for an owners manual to an E-3 Gleaner combine. Actually, just looking for any engine specifications in the owners manual. You can text or call 319-360-4788 or PM me please and thank you. Merry Christmas !!
Bruce(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 7:36pm
Is this what you are looking for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 7:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 8:51pm
It is exactly what I'm looking for. Unfortunately, there must have been some disconnect between Milwaukee (where the engine was built) and Independence, Missouri (where the combine was built).  I have seen Gleaner E-3 engines that have "Z" compression ratio codes stamped on the blocks serial number. The "Z" code was to indicate an 8.0 to 1 compression ratio, which should have increased the engine HP to 67 at 1650 RPM.  The spec's page in your book still shows the older model "E" specs of the "M" code which was 7.25 to 1, same as a regular D-17 engine, which was 63 HP at 1650 RPM. The E-3 was to have gotten a HP up-rate from 63 to 67 over what the model "E" had. Thank you very much for the help. It's pretty clear the compression ratios were changed from the M to Z codes, but I guess the owners manual printers weren't informed !!  Kind of like the Federal Government was involved ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2022 at 9:10pm
I have an E book too.
 It does'nt have a spec page at all
 just says Allis 226
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2022 at 6:55am
Just got off of the AGCO parts website and all model "E"'s had 7.25 to 1 pistons and all model "E-3"'s had 8.0 to 1 pistons. No serial number breaks on either. So, the E-3 was given a HP up-rate of I think 4 HP just with a compression increase. Carbs and camshafts are identical between them.
This page was generated in 0.081 seconds.
