gleaner e shut off valve for header |
Post Reply |
mruhlig77
Orange Level Joined: 19 Aug 2014 Location: central Indiana Points: 559 |
Posted: 24 Oct 2020 at 8:28am |
There is a hydraulic valve behind the right drive tire area....assume for header...but cannot find it in my books....anyone have a page number or is this a modification....Mark
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7970 |
My F2 has a 1/4 turn valve at back edge of ladder platform next to cab which closes off left hyd cylinder to lock head. Follow lines and see where it goes. I put a 1/4 turn on left cylinder itself on my A2 to eliminate possible hose failure. Could reach it with foot to operate before going underneath. The original metal cylinder lock can't be used when equipped with helper springs for bean platform.
MACK
The valve you see is a hydraulic accumulator , not a shutoff. MACK
SteveM C/IL
an accumulater on an E? Why?
MACK
They were used as a header control, had a skid plate under sickle bar. MACK
SteveM C/IL
So that would have been before the likes of the M&W header control? My A2 had one of those with an add on H/C floating bar. The rod with all the fingers rode against the top side of shoes
mruhlig77
Thanks Mack...but mine has none of that fancy stuff...it is a 64 with regular head...It does look like an accumulator behind the shut off valve..thanks Mark
Steve g
Bronze Level Joined: 17 Jun 2017 Location: Cen.ohio Points: 101 |
A lot of good conversation dismantling the E that I have I'll have to double check all the hydraulic lines I have not seen any kind of shut off valve going to the hydraulic cylinders
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
Is there a transversly mounted cylinder under the throat ? Our F2 has one but has never been cracked open, ours has an aftermarket E/H header control.
mruhlig77
Found an article today that suggests that valve I see is not a shutoff but rather an adjustment valve for he weight of different headers....he accumulator is for smoother motion of the grain head installed...Mark
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Does the valve look like this? My E has a cable operated system using this valve to control header height. When you get it set right the header will follow the ground. It has an adjustable flow on it to speed up or slow down the response. There’s what looks like a rake under the cutter bar that pivots up and down to work the valve. |
mruhlig77
valve in question...
Post Reply | |
