Gleaner Concave Bar Offset Hole Direction
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner Concave Bar Offset Hole Direction
    Posted: 14 May 2025 at 9:52pm
On the older gleaners with the bolt-in channel style concave bars, does it matter which direction they're installed? The holes are offset to one side.
The concave on the door looks like it only clears some nearby screw heads by flipping it one direction, so I am planning on carrying that over to the other concaves. My CII manual says nothing about it so it must not be important?
Picture of one concave one direction, and the other concave with the holes opposite.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 9:59pm
Short side forward so the channel doesn't get lifted up off the floor.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 8:30am
They look a tad worn... From the factory they had 5 concaves - for hard to thresh crops - we always pulled #2 and #5 out for corn and soybeans. The beauty of the conventional Gleaner - can run 1 2 3 4 or 5 bars depending on degree of threshing needed. CII and M/M2 same cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 10:04pm
That logic makes sense. I can't do that with the one on the rock door though due to clearance to the nearby screws (picture below). I will flip the other ones on the concave door the way you describe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 10:12pm
Cut off the concave ends just enough so you can. You do not want to run them backwards
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 10:21pm
They are slightly worn. I got a set of 5 new ones from my dealer and mine are down a good 1/16" or so, but the owner/manager said they still had life in them and I should just run them.
They're chewed up in a few spots from rocks too. The owner of the combine before me had concaves 3, 4, and 5 in... Nothing on the rock door, so it probably wasn't kicking open as often as it should and the rest of the concaves took the brunt of it when he was combining soybeans. I'm putting them back in the 1, 3, and 5 positions since a few guys around here have said they don't have issues with wheat left in heads, and then they leave can just use the 1,3, and 5 positioning for soybeans. If it doesn't work out I'll have to install the new set of 5. I assume mixing and matching new/worn concave bars wouldn't be ideal with the varying cylinder clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 10:22pm
Interesting and thanks for the insights. I can probably take just enough off of the corner with a grinder to clear the screw heads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 10:25am
While you are at it would be a good ideal to "0" the cylinder.  Run the cylinder down until it touches the concave bars evenly on both sides. Then reset the gages on the left and right to "0" as well. Now you know the true clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 10:41pm
I will definitely do that. The first thing I did was back the cylinder off from the concave bars as much as possible. Then at some point I realized the concaves were mounted to a hinged door that you could drop down by remove the two larger bolts/nuts. I feel kind of dumb now, but they don't show it anywhere in the CII manual I have - only the rock door.
