Gleaner Combine model F 8 bolt drive wheels
BRAD R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BRAD R. Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner Combine model F 8 bolt drive wheels
    Posted: 08 Apr 2010 at 11:00pm
23.1 x 26 tire size will these tires and rims fit my 185 Allis tractor without any modification? Has anyone ever done this?
                  Thanks
                          Brad from Kentucky
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 1:05am
It depends is it the "big" 8 or the "small" 8. The 185 has a rim thats 8 on 8" with a 6" center hole. The "small" 8 rim will fit as long as the tires do.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2010 at 9:31am
Our 1976 F had the large hub, and I thought it was 10 bolt?  It think the tire will fit under the fenders just fine, but you will need an adaptor or weld a plate in the center to connect it to the axle.
Just looked in the parts books and all I find for F combines are 10 bolt wheels...
The innovators offer what others will imitate.
This page was generated in 0.586 seconds.
