Gleaner Auger height
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner Auger height
    Posted: 22 Oct 2016 at 8:18pm
Hi, Just wondering If the auger needs to be fully extended to unload? It is tall enough for a 200 bushel wagon all the way extended but I bought a 400 bushel wagon and It is pretty tall. If I retract the auger it has a higher reach but Im not sure if It is meant to do that?
It is a hydraulic fold auger.
Thanks in advance
Nick
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 8:35pm
If positioned perfectly a K could dump into our 350 bushel wagons.
bakwoodsfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bakwoodsfarm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 8:37pm
Take an 1 1/2" pipe and cut it 1 1/2" long, then cut it in half length ways. Use a hose clamp to put it back together on the unload auger cylinder. This will give you about another foot of unload height. Won't hurt anything.
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 8:50pm
I did the pipe on the cylinder. It raised the end of auger at least 12 inches. I can now unload without hitting my nephew's trailers. rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2016 at 8:54pm
If you don't want to replace the ujoint, better extend all the way. If the ujoint clatters at all, it won't long.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 12:54pm
My F2 has a stop on back side of swivel.I added a new one a little short of original.Raised it about 6in.Just clears the bows on my hopper bottom if both are on flat ground.I almost never unload full throttle,usually 1/2-2/3.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 8:33pm
Make sure to keep auger u-joint at pivot well greased.
jason82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jason82 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 10:03pm
I just posted this of our F2, shows dumping into a tempie grain trailer.
Gleaner F2
Edited by jason82 - 23 Oct 2016 at 10:04pm
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 10:34pm
What model did the pipe on the cylinder trick work on? I would like to get some more height on our l series combines but either don't understand the trick or don't think it would work on an l
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 5:03am
when I needed extra height for my "K", when dumping into the semi, I had 2- 2x12's nailed together about 2 ft long. layed it on the ground and drove up on it with the left drive wheel. worked well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 5:38am
Okay, I should be good then, It just looked low when I was dumping in the small wagon. Maybe my depth perception isn't too good. lol.  I wont find out for a few days until this rainy weather stops so I can finish my beans.
Jason 82: Nice soybeans, I wish mine were running 65 bushel an acre.  How many acres do you run through that combine?
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 6:37am
What is your 400 bushel wagon? We used to dump in J&M 385s with an F3. Picked the auger up some never hurt anything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 8:07am
It is a used bruns wagon. They are made here in Ontario
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 9:10pm
If we didn't do that on our L3s we would never get them dumped. If you raise it to high it should shut off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 11:33pm
Them L's got electronics.The F2's until the latest were manual and you can fold the auger in while its running....it won't still be running if you get it folded LOL!
