Gleaner A430 Gathering Chain ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner A430 Gathering Chain ??
    Posted: 05 Dec 2019 at 7:35pm
What would/could be the #1 reason for a gathering to to jump off of the sprockets? There is only 1 "problem child" on the head giving issues this late season. How you guys keep track of 12/14 row heads baffles my mind Wacko
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 8:44pm
Bad bearing in front sprocket, front sprocket plate loose, or loose bearing in rear bearing housing.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 9:19pm
Just looked on the parts book site, the rear housing bearing replacement does not look like fun at all Cry
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 10:16pm
I had a black head doing the same as you describe.  It turned out to be the slide bar in the grove that the front sprocket assembly slid in to keep the chain tight was worn so thin it let it twist.  Took me about 30 acres to figure it out. it drove me nuts!
Oh, and the wide heads (12/16 row) are just as much fun, but oh man is it nice to sit and watch them work when they are set up right!
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 6:07am
Amos,do you recall the "fix"? Was it just a matter of shims or major re-building of the row ?
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 6:45am
I just replaced the slide bar that was bolted on,  I think it is 3/8 by 3/4 flat steel,  Mine was worn down to 1/2 inch wide.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 7:08am
I think that piece is hardened steel so making one from mild steel wouldn't last long.
Wink
I am a Russian Bot
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 11:30am
Mine made it 1000 acres, the rest of the head was finished then.  I can't figure out why just the one row gave trouble and the others didn't.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 6:24pm
Sometimes its worse because the gathering chain is wore out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2019 at 2:31am
streched chain
