Gleaner A header cylinders
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner A header cylinders
    Posted: 10 Aug 2015 at 6:10am
OK, dumb question but just HOW does the header manage to stay up for ever? I mean every other hydraulic system I've had/seen sooner or later whatever is up does come down ! Usually the weight of the load will push the oil backwards.
Just curious, like my new kitten.
Jay
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2015 at 7:32am
Most hydraulic valves only use a fit to spool to keep oil from returning. The header valve uses a poppet to keep oil from returning that takes hydraulic pressure to unseat it. Does two things that most other valves don't do. #1 a safety to keep header from going down unless there is oil pressure to let it down. #2 keeps header from leaking down over time. MACK
