getting the temp gauge out of the block
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Topic: getting the temp gauge out of the block
    Posted: 02 Jan 2019 at 3:16am
working on an old farmall h replacing the gauges and painting and decals, cant get the stud for the temp gauge outta the block. tried heating and no luck any ideas its some kinda on there thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 6:26am
yeah, I gots one of them too..... still a 'work in progress'
there's 2 kinds of sensors. one goes into a 'well' that's mtd in the block, the other just gets screwed into the block, usually with an adapter 'bushing'.
One problem is that most aftermarket stuff is actually Metric, 'made' to fit Imperial....
You might win by putting a pipewrench on the 'nut' closest to the block. That way when the metal deforms the sensor will keep it reasonably intact.
I'd try a quick,hard pull but not too far. Rust has 'sealed' the threads. IF it loosens, go back and forth a zillion times, if you try to just crank it out, the rust WILL rebind the pieces up solid again, maybe worse !
It's one of those ..gotta have patience and THINK before you act PITA jobs.
Now if you want to practice...... come on up !Wink
jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 5:24pm
You could try the wax trick.  I grow tired of writing about it, so here's a video.  Just remember, from experience, bees wax seems to work best...
[TUBE]7qqMXXGgFQg[/TUBE]
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 5:37pm
mite haft to split it to get the presser off to get it to turn out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 12:19am
I got it! thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 12:45am
how did ya; get it to come out ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 8:28am
ya HOW, and did you buy a lottery ticket !!??!!
Jay
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 2:02pm
After asking a question and then saying you found the answer... ya gotta give us the answer.... inquiring minds want to know
This page was generated in 0.151 seconds.
