Getting HD7G and NEED a PART
AmericanHomestead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Topic: Getting HD7G and NEED a PART
    Posted: 17 Mar 2017 at 12:05pm
A friend of mine is giving me his HD7G for cheap.  He's up in his 80's and his wife is bugging him to get rid of all of his equipment and finally hang it up. SOooo. I'm buying his HD7G and it needs a transmission oil pump.  He stripped it about 2 years ago.  He says the tractor runs fine but needs this part fixed. He says he didn't let it warm up enough before running it and that is how it happened.
I'm totally new at this and I'm new at the forum so I can learn.
Here is the part I need. I emailed member "DoctorCorey" as it appears he has the same HD7G loader that I have. According to his profile, he hasn't posted on this forum since 2015.
Here are the pics of what I need.  Notice the stripped splines on the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 12:50pm
Corey just emailed me back and he has the exact same part! HA!  awesome!
Check us out on Youtube:
https://www.youtube.com/user/AnAmericanHomestead
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 5:22pm
If anyone has any advice for a new HD7G owner, I'm all ears. I do have the original 2 volume HD7G service manual by Jensales.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 8:15pm
I am not an expert to be giving HD7G advice, but I am enough of a woman expert to advise you to get them parts off the kitchen counter before your wife sees them there! Darrel
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 8:23pm
1I was noticing that too Darrel... unless that woman is one in a million... then American HomeStead is a doubly lucky man,,,
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 6:20am
What is the brand of pump or pump manufacturer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 9:04am
:) pictures taken when the Mrs was not looking. Removed quickly. ;)
Orange, the pump is a stock original from the 7g.
Anyone have a list of checks before I load her up and bring her home?
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 9:23am
AH - So no tag on the pump -  If no tag - take the shaft and coupling to a machinist - pretty simple job to make a new one.
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 9:28am
Say there American Homestead. I thinks you better keep hanging out on here for years to come. It could be a lot of fun. I don't have any insight for you on your 7, but I bet it'll be a lot of fun. If'n you know how to put pictures on here, we'd love to see some. Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 10:12am
Orangeman
Yeah, one guy on facebook told me that 12 spine shafts and couplings are like gold.  And after doing some research, he's right. I can't find 12 spline ANYTHING.  9 spline, 13 spline, 14 spline yes, but not 12.
The tricky part is these shafts and couplings are hardened to take extreme pressures and just milling a piece of steel won't work. It needs to be properly heated and quenched to harden the metal.
I'm looking forward to putting this monster to work but I'm so worried about breaking things as old as it is and having a money pit. Cry  Life is an adventure!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 11:22am
On another note,what would cause the stipping here on the pump?  The former owner told me it's because he didn't let the 7G warm up 20 minutes before operation.  But I have seen videos on youtube where people fire up their 7G and drive off no problem.
Could there be another issue I need to check for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 11:35am
I think I'd be takin a look inside the pump before I spent any money on it.
 When I was still workin, we repaired all kinds of equipment like that in the shop. Shafts can be welded up and recut and if the right process is followed, it can last a long time without "heat treat and quinching." There are work hardening materials out there too, kinda tough to machine sometimes, but a good shop will tell you if they can do it right.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 12:05pm
 Your pump must be a CESSNA PUMP  and the shaft parts number should be70628246 and you better check your inside pump before order a shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 12:38pm
Cessna pump - if looking inside the pump check for a wear plate.  A spec book for the pump would provide much needed information on specs. flow capacity in GPM and pressure requirement.  Might also find some specs in a AC 7G service manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 12:57pm
Correction on the pump, is now a EATON Cessna, I had to order the nose housing as is broken on yours and get the seal package as mine was sucking air so bad. I have a donor tractor I pulled the engine/converter assembly out of, they had welded the shaft at the converter end gear. These are my 'Good ones' still in use which I believe are 14 spline, going to take to a Detroit diesel dealer and see if can match to a blower drive as it appears similar save the pump end collar. The other option is to convert the entire mess, pump, drive gear and couplers to something else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 12:59pm
The reason I say convert is that Minnpar can build a order for these but will have excess cost to have made, that cost is passed on where I was quoted over three hundred for just the shaft WHEN made available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 1:05pm
The former owner said he took it to a few fab shops and they didn't want to mess with it.   I have a different pump squared away and probably a coupler too.  I just want to be sure of the cause of the stripping before I just throw it on there and assume all is well with everything else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 1:18pm
By all of the rust it may have not been receiving enough lube from the converter or not assembled with the correct lube. There is a vent line from that housing cover for the drive gear that sends any vented gasses and fluid to the trans/final case as I remember. Mine has the hose early units had just a vent.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2017 at 3:43pm
Hub City makes splined shafts and couplings. A bearing dealer should be able to help. I do not think they make a 12 spline. I did have them make a special coupling for me but that was years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 7:52am
Are you sure it is 12 spline. You should look for a new pump. The pump mounting should be a standard. The capacity (GPM) can be determined by the width of the gears. I think it is a gear pump but not certain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 11:24am
It is a gear pump, two section taking suction from both the trans sump and the left hand side strainer. Is a Eaton Cessna and according to the hydraulics shop I use very much still available. Big issue will be the shaft and the couplers. The gear that drives from the converter is splined for this shaft not adapted. Would require a lot more to get it replaced that the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 1:38pm
So my issue now is finding a shaft and coupler.  I got the pump on the way from Corey (thank goodness) but now I need to find the shaft and coupler.  I have the stripped ones but who do I send it to so that I can have a new one fabbed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2017 at 3:45pm
Find a local machine shop that does prototype(small job) work. The majority can cut splines this small and work with better harder materials. Most will have access to other companies that produce spline shafting or couplers as well.
Also as I noted above look for a major hydraulic repair shop close by. Mine is 40 miles away. If they can locate materials they will attempt to purchase or build what is needed.
Need to ask, was the ear of the mount already broken or loos? If it was that will allow the pump to shift under load and do as shown. There is no tag for these pumps, the part numbers are right in front of you on the mounting flange. Eaton Cessna numbers.
Edited by DMiller - 20 Mar 2017 at 3:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AmericanHomestead Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 8:51am
Thanks everyone, will post updates as we get this thing running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 7:36am
Just as  a future reference for your associated hydraulics shops, these are EATON 26507-RBM , Series S-26 hydraulic pumps.  Per my supplier for hydraulic parts he SHOULD be able to get these but would be in either 9 or 13 spline, then would have to modify or convert the drive gear in the converter(small side cover) to one of these and use available shafts.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 8:14am
Ditto!
My wife would be telling me to get them out of here, they don't belong here!!
Imagine that!
michale34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 12:54pm
Yea I got caught working on a chainsaw one time on the kitchen table I had a couple of news papers under it thought it would be ok but it wasent. I bought a dish washer at a auction one time for 10 bucks to put in my shop for washing chainsaw parts worked like a charm when my wife saw it she said I better not ever catch any parts in my dishwasher. but what she don't know I have used her oven for heating chainsaw crankcases in to replace the crank bearings lol
Edited by michale34 - 07 Apr 2017 at 12:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 3:59pm
I have cooked out welding rods in our oven!!   SHHHHH!
Edited by DMiller - 07 Apr 2017 at 4:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 9:22pm
one time my mom went to get some meat out of the deep freezer and there were 4 sleeves for a hd6 in there dad was watching wrestling and mom yell what the - - - - is this in my freezer
Post Options Post Options   Thanks (0) Thanks(0)   Quote michale34 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 9:26pm
after that he wrapped them in plastic bags in a ice chest dumped ice on them with rock salt and sit over night
