Getting gas out of a car gas tank |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7513 |
![]() ![]() ![]() ![]() ![]() Posted: 03 Nov 2021 at 8:31pm |
I am trading in my old 2007 Mazda 3, but don't want to give it in with a full tank of gas. I am looking to get it around a 1/4 tank. I am not sure if a siphon hose will work going down the filler tube. I have heard they can get stuck in there. What's the best way to get some gas out of the tank? Any ideas? Thanks in advance!
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54278 |
drive it a little while longer...
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6493 |
I can drive my F250 by it and the 460 will pull all of the gas out of it.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
yep...use the smooth hose and if the hose does gits stuck trying to pull it out, shove it on in all the way, it won't take up much room in the tank.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5143 |
Find the fuel filter and hook a small pump to the end that goes to the engine.
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 8108 |
Just tell the dealer you need $100.00 more on trade in.
fixer1958 ![]() Orange Level ![]() ![]() Joined: 13 Feb 2010 Location: kansas Points: 2434 |
You could take the fuel line off the fuel rail and jump the fuel pump relay.
1951WDNWWI ![]() Bronze Level Access ![]() ![]() Joined: 11 Jul 2011 Location: NW Wisconsin Points: 118 |
I attached a pressure tester to the port on the fuel injection rail and attached a hose to the relief valve on the tester. The car pumped out two five gallon cans of gas in short order. I think that is why the tester was designed that way.
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
Have a helper. Remove fuel line from carb. Have a pal use a rag with an air tank, put it in the inlet. Pump air into the tank. Easy.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5035 |
I could probably put you in touch with my neighbor's kid. He sure seems to know how to get gas out of my tractors, if I happen to leave one outside.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24728 |
drill 5/16" hole in btm of tank,put tray underneath first....when drained, plug hole with screw/rubber washer. do this when scrapping vehicles... really though ,how much gas is in it ? say 80L tank... 1/4 full is 20 L, so maybe 5 gallons. Up here that'd be $30 MAX, you... $15 ??($3/G). Only way you 'win' is if you're NOT worth $15/hr, cause it'll take you that long(or more) to empty it. Bad news is ..lower it too much, crap in btm of tank (water),gets into engine, won't start, dealer says 'nope...it ain't running like it was, deals off'.....
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34161 |
I agree Jay, NOT worth the effort for the insignificant gain. My wife will run a car damned near to empty to trade one in, asked her why and she just wanted her moneys worth yet will buy internet crap to sit on a shelf in a closet for $$ BOOCOO bucks and never see it as a loss or buys/throws away $$$ Healthy Foods I suppose she figures just having in the house and leaving to rot as taste bad is by proxy/Osmosis a Good Diet. None work out to her fantasy dreams.
Walker ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: oh Points: 8974 |
Drop a lit match in.
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Electric pump and long 3/8 hose will work but the pump will cost more than the tank of gas is worth! Leave it in or as stated---- DRIVE it out!
