Getting a hose on a pipe
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Getting a hose on a pipe
    Posted: 01 Mar 2020 at 8:37pm
It shouldn't be so hard really, but for the life of me I can't get the D21 turbo outlet hose to fit onto the intake pipe.  I have the correct hose from AGCO for the Airresearch turbo and found an original intake pipe (part number 74025927), but you will see that both outside diameters are pretty much the same.
Any hints to get this hose on?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 8:47pm
It will go, just work it around there.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 8:59pm
I used to use a lot of WD40 on motorcycle grips to get them on.
Lots, like wet, slide,twist grip on FAST then 'locks' on when WD40 evaporates
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 9:01pm
A radiator hose hook might help, also make sure that hose is a little warm, stick it in some hot water...Wink
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 9:03pm
The small end (2 in ID) goes on the turbo. The larger end (2 1/2 ID) on the tube.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 9:09pm
similar to what Jay said... we use to pour a spoonfull of gasoline into the handle bar grip and slosh it around... then shove on real fast.. gas evaporates in 1 minute and you good to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 9:36pm
Foamy window cleaner works well and evaporates soon after.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 9:44pm
You didn't give the PN of the hose. If it is an 74027975, one end is smaller than the other.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2020 at 9:53pm
D-21's never had an Air Research turbo and I think your cast aluminum crossover pipe takes a bigger hose for the Thompson/Rajay brand turbo.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 6:01am
Late D21 had Air Research Agco Parts On Page # 54
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 6:11am
Correct. But my point was if it is the cast aluminum crossover tube, that one isn't for the Air Research. It's bigger diameter.  The correct tube is tail pipe thin tube.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 10:02am
   The outside dia of the tube is 2 3/16, the inside dia of the hose is 1 15/16 that aint never going on, even superman couldn't push that on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 10:20am
Maybe wonder woman, Fair Valley Performance sells many different dia of turbo hose.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2020 at 10:57am
silicone spray works awesome for your exact problem. (for me anyway)
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2020 at 8:41am
Had a similar problem with a truck where hose went bad - truck parts house had bulk hose and found one to fit , they cut a 1' length off the bulk piece and sold it to me , only needed 6" so now have spare but saved my bacon on the job
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2020 at 7:34pm
I don't know about the D21's, but the D19's used a reducer hose when changing from the Thompson to an Air Research turbo. PN 74027975, It's the same as used on 190XT. The AGCO part is pricey ($40). There are auto aftermarket air intake reducer for around $10. May not be orange. I've discovered this when working on the D19 I bought that had been converted to an Air Research.
concretepumper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote concretepumper Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 9:02pm
That is the correct hose for an air research/Garrett but the cross over tube is for the early tompson style turbo. You will need to get the cross over tube from a 210/220 for everything to plumb up correctly. The cast aluminum cross over tubes don't line up correctly with an air research turbo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 9:06pm
Yes, I have the AGCO hose PN 74027975 - it is the same diameter on each end.  Thanks for the link to the summit racing website.  I will double check the overall measurements and probably get one there.  The tractor did come with the thin tube that Dr. Allis mentioned, but I do not like it for 2 reasons - aesthetics and functionality.  Looks puny and it cannot accommodate the manifold heater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote concretepumper Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 9:17pm
If u use a 210/220 intake manifold, the heater element is plumbed into the intake manifold
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 9:34pm
Years ago when we put a M&W turbo kit on a Deere and the dealer said to put the turbo hoses in a bowl of hot water  for a few minutes and they would slide onto the pipes easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2020 at 9:36pm
Then I have to buy a 210/220 manifold.  I still have the original D21 manifold on the engine.  I'll study it on the weekend.  If a $10 hose from Summit does the trick, I'll be laughing.  I already bought the aluminum cross over pipe which houses the heater element.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2020 at 8:28pm
I just found one on ebay for $3.82 ea.
I ordered 2 for my D19's. One already has a TO4B and the other I am installing one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 7:56pm
The aluminum crossover pipe is definitely not meant to go with the Airresearch turbo :(
No hose in the world can fix this!  Sad to say I will have to put the skinny pipe back on and forgo the manifold heater.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 7:59pm
Get a hose that fits the aluminum pipe. Cut off a piece of the smaller hose that fits the turbo, about 1 1/2" should do it.  Slide the big hose over the little hose and clamp it together. It will work. Been there dun that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 4:39pm
The "bushing" method has been applied successfully many times
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 6:02pm
A good welder/fabricator could get that to line up, but air horn pre-heaters are over-rated, anyway, IMHO.  Plumb in a thermo-siphon electric heater, and you don't have to do no fabricating, or kill yer battery(s) with the air horn heater...Wink
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 7:58pm
I don't know if this link will work. But I had the same trouble last summer.  https://www.allischalmers.com/forum/forum_posts.asp?TID=158965&KW=turbo&PID=1355407&title=7000-turbo#1355407
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 10:57pm
Manifold heater works good enough on my 220 however,if it's cold enough to use it,I'd rather have a block heater. Will start at freezing with just M&W's,no heater. I don't start it that cold but I had to try it once.
