Charlies D10 Series 2 Project |
Post Reply |
264 Charlie
Bronze Level Joined: 18 Jun 2024 Location: Gainesville, TX Points: 8 |
Posted: 18 Jun 2024 at 9:40pm |
I just picked up a D10 Series 2. I plan to use it as a working tractor for spraying and running a side-mount sickle for cutting around my pond and banks. I'll do a tune-up and see where I go after that. It runs and shifts well. I do get a bit of noise when the clutch is depressed. I might be splitting the tractor soon.
The paint looks original and is well worn but solid color, so I will likely keep it for more of the original look. I like the color, so I need to find a good match; it's a 63 so assuming PO2 I've never seen exhaust on a D Series as this tractor has; it Looks factory, though. |
264 Charlie
Sorry for the huge phots, I try and not do that again.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80226 |
when you push in the clutch, you get a "noise".... can you grease the throw out bearing from the bottom ??? ....... Had a noise on a couple "B" tractors and that solved it..
Thanks(1)
you camera takes photos about 4000 x 3000 pixels... This site does not "auto resize"... I opened your photos in PAINT and resized to 18% to get them about 750 x 550 size.
264 Charlie
Thank you, great to know. I will do a service on it next week and see what's what.
does it have an under hood muffler... or just a straight pipe off the manifold ??
Eric B
Orange Level Joined: 09 Feb 2012 Location: British Columbi Points: 922 |
Nice little tractor for sure. Is there much play in the steering? If there is not, it's probably a low hour tractor. The steering boxes seem to be a bit of a weak point on these. I really appreciate how fast 4th gear is. Thanks for the pictures.
264 Charlie
It has a muffler. I did see that a low-clearance model is an option; this is the first time I've seen one.
264 Charlie
There is not much play, the pedals don't have wear, and from what I can tell, it's only got one coat of paint. Edited by 264 Charlie - 19 Jun 2024 at 1:58am |
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4670 |
On those series II & III tractors the noise with the clutch pushed down is most likely the pilot bushing on the transmission driveshaft instead of the clutch throwout bearing. If grease on the throwout bearing doesn't cure it, that's where to look. That pilot bearing has no way to lubricate it, therefore it wears out quickly. I've encountered many of those series II & III tractors having that issue.
Yes that Low discharge exhaust is an Option. I've seen a few however I've never seen on that the muffler wasn't burnt out. It's nice that you have the normal exhaust factory hole filler.
GeneD14
Silver Level Joined: 17 Sep 2009 Location: TN Points: 247 |
Charlie,
Great find! The D10 was always one of my favorites.
Edited by GeneD14 - 19 Jun 2024 at 9:29am |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7304 |
That tractor has the under hood exhaust. My neighbor has a D12 like that.
264 Charlie
I noticed the PTO stays on all the time. I'll dive into that repair as soon as my repair manual arrives.
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10608 |
That tractor was a drawbar work tractor mostly. If the 3 point had been used muck, the yokes wouldn't stand up like they do. JMHO, Tracy
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5323 |
Re the PTO stays operating Your D-10 has Live PTO. It is engaged and dis-engaged by the Upright Lever located directly rearward of the Hydraulic Control Lever. Dis-engage by pushing the Lever fully rearward. Lock it in place by pushing it outboard and locking behind a little Tab. Gary ...................................................................... Your D-10 also has Live Hydraulic. The Hyd. pump is located on the rear of the Tractor above the PTO. It is driven by a long shaft that is splined in to the Flywheel. Pushing the Foot Clutch does not stop the Hydraulic Pump. Just 2 of the great features of the Model D-10 and D-12. Edited by Gary - 20 Jun 2024 at 5:25am |
PaulB
As the Series II & III PTOs are Independent and use a separate clutch you want to leave it engaged unless you are hooking up an implement or have one hooked up that you don't want it running. Tuning it off and locking the brake to keep it from turning is just like holding the engine clutch peddle down all the time, thus causing undue wear on the clutch pack.
It would be a help to you to get an OPERATORS manual for a series II D10/12 to learn all about the tractor's particular features and how to properly use them.
264 Charlie
Thank you for the input. I have the manuals on order and expect them to be ready next week.
Currently, the PTO lever does not disengage the PTO. It stays running regardless of position. |
PaulB
Most likely the PTO Brake is worn out from improper use or mis-adjusted.
Post Reply | |
