Hillside B? |
Post Reply |
brkfldj
Bronze Level Joined: 13 May 2010 Location: Sharpsburg, MD Points: 166 |
Posted: 26 Mar 2019 at 9:32am |
Saw this B while traveling through the hills of Tennessee. In my limited experience farming, I've never operated a dual wheel tractor, but have generally assumed that duals were to utilize available horsepower or lessen compaction. Those perameters don't seem appropriate for a B. Is it logical that the duals may have been installed to serve as an
anti-roollover precaution? |
Democracy is two wolves and a lamb voting on what is for lunch. Liberty is a well-armed lamb contesting the vote. ——— Ben Franklin
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8144 |
That's neat. Or for wet ground
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11202 |
Must be a late model B, with those bolted hubs/rims.
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
Looks like somebody added a hand lever to hook to the clutch.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4408 |
I thought from the title it would have had short tires on one side and tall ones on the other Or would that have been a WestVirginia B?
If you can't make it GO... make it SHINY |
Dick L
Orange Level Joined: 12 Sep 2009 Location: Edon Ohio Points: 5082 |
The front tires don't track with the rear as most B's. Also the gap between the rear tire and fender is a little wide for a B. I am guessing it might be a C with a B front.
littlemarv
Orange Level Joined: 10 Jun 2013 Location: Wisconsin Points: 1826 |
Looks pretty badass to me...
The mechanic always wins.
B91131, WC23065, WD89101, CA29479, B1, Early B10, HB212, 416H |
LeonR2013
Orange Level Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
I think you may be right Dick. Not that amounts to a hill of beans. But it just doesn't look right to be a "B", but what do I know? Be that it may, thanks for putting it on here. Leon
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50518 |
I bought a west virginny backhoe, once, only had one tooth on it...
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11548 |
Was the tooth in the middle or on one side Dave? Probably wasn't a bucket tooth, it probably had a "buck tooth"! LOL! Steve@B&B
CrestonM
Orange Level Joined: 08 Sep 2014 Location: Oklahoma Points: 8357 |
I can see where they'd help for flotation, but does a B really have enough power to make good use of them when pulling implements, like a disc?
I've given thought to dualing mine up for more traction/flotation.
bemer848
Bronze Level Access Joined: 29 Sep 2013 Location: southern IL Points: 81 |
That picture brings back old memories to me. When I was young we had a C Allis and my dad rigged up duals on it and I pulled a 10' tadem disk with it. Yes it had power to pull it.
Dick L
Pulling a disc on plowed ground will pull easer with duals. If you notice when on loose ground your single rear tires are not on top of the loose ground. As your pulling the load the tires are trying to climb up on top as it moves forward. The tires are turning faster than your forward movement. That takes up horse power. When you add duals the tractor still is not totally on the level with the top of the loose dirt but will be less to sink in and forward movement will increase. When I added duals to my Oliver 1850's I was able to step up one gear. It made going up hills on loose ground much easier also. If your doing fitting of ground and wondering about loosing power by doing so, fear not. |
Dick L
Taking another look at the inside rear wheel I see the wide side of the rim is to the inside with the short side facing out. This makes me sure it at the very least C final drives. |
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2204 |
Row crop duals???
Farmswithjunk
Bronze Level Joined: 26 Mar 2019 Location: Vevay indiana Points: 3 |
The previous owner of my b replaced the drives with the ones off of a c, the press on hubs wear out quickly in the hills
Post Reply | |
