DD A-C Grader
L Karg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote L Karg Quote  Post ReplyReply Direct Link To This Post Topic: DD A-C Grader
    Posted: 25 Jun 2015 at 11:07pm
Anyone know where I can find a new or used factory power steering pump for a very late model DD Allis-Chalmers grader?
Thanks
Larry Karg
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 7:44am
Hi Larry.   Calvin S. and I have been trying to install+ a Behlen power steering unit on a 1967 'D' grader. It appears that A C may have used different pump assemblies. We have seen a pump installed on the R H side of the motor. It is driven with a double grooved V belt pulley that is driven from the crankshaft. We have seen pumps installed on the crankshaft. We have seen pumps driven from the distributor.
   Do you have any pictures of your grader, and in particular, the pump and oil reservoir. Is your unit a round or square beam unit? What year? I am curious as to whither you have the auxiliary transmission. It sure works nice when you can reduce your travel speed by 66% when you need less speed and more H P..
   Ross D.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 1:05pm
Nice grading job !!!!
This page was generated in 0.320 seconds.
