8 hp B&S surging
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 8 hp B&S surging
    Posted: 01 Jul 2025 at 7:08am
My tiller engine had a carb that elbow broke on. Couldn't get the elbow. Bought new carb and installed it. Surges like hell. Cant figure out how to stop it. Needs almost full choke to run.  As usual, made cheap with no easy adjustment. What is likely cause? Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 7:21am
governor spring is 'wrong'? either too 'light' or 'long'.
'slop' in the system allows engine to run fast them slow, fast then slow,never finding the 'happy' point.
other possibility, governor rod is in wrong hole in the throttle plate. I now take a picture or make a drawing BEFORE I tear stuff apart. You 'might' be able to see wear marks in the proper hole, maybe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 12:05pm
Jay, it only had one arm attached to it. I put it back same as old one. I will see if linkage is too tight. The other carb did fine but pissed out fuel in broken elbow. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 1:12pm
hmm, EVERY gas engine I've ever worked on has had a light tension spring  with the carb-guv rod sitting inside of it.
maybe post make/model of engine ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 1:19pm
jay, it is a model 196432 type 1065-e code 0003081a HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 1:33pm
you should have a srping #232A, rod212 is the carb-guv 'control'
I googled"B&S 8HP 196432 type 1065-e" went to jacks small engines for diagram.
hopefully it helps ?
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 4:45pm
grab the throttle lever BY HAND and hold it... and OPEN to get more RPM.. see if the governor is FIGHTING YOU to cut back... or if carb main jet is too small and feeding TOO LITTLE FUEL....
might be able to take the governor spring OFF and run the engine BY HAND ( do not over RPM) and see how the new carb acts ??
if its not the THROTTLE, but the CHOKE must be mostly shut to get the engine to run, then the CHOKE is cutting down on the AIR FLOW... meaning there may not be enough GAS flow.. or main jet is TOO SMALL.
Edited by steve(ill) - 01 Jul 2025 at 4:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2025 at 8:29pm
Steve, I have that spring and rod on mine. I did as you said, it does run with the choke on but still surges. If I can find a new elbow, I will put old carb back on. It ran fine, just dangerous the amount of gas it pissed out at elbow. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2025 at 7:55am
Tracy, i have not seen the elbow "leak"... but is it something that could be patched with JB weld ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2025 at 3:02pm
Steve, it is a overshot molded plastic over brass tube. I got one at a small engine supply. Put it in and installed old carb. Tiller has a small amount of surge still. Tiny bit of choke stops it. I need to remove jet and enlarge it a few thousandths. Have to wait though, it aint easy to get out. Thanks, Tracy
This page was generated in 0.128 seconds.
