8030 injectors |
AllisandGleaner
Topic: 8030 injectorsPosted: 02 Jan 2018 at 5:31pm |
Where could I find some injectors for my 8030 or if I could Find some tips that would work even better.
Michael V (NM)
Posted: 02 Jan 2018 at 6:13pm |
Surely you been on this site long enough to know injed is place to go...
Before I knew that,, can't go wrong with a set from Abilene machine... |
AllisandGleaner
Posted: 02 Jan 2018 at 6:19pm |
They don't have any for the 8030s.
Michael V (NM)
Posted: 02 Jan 2018 at 7:08pm |
Hopefully someone else will chime in with some other ideas...
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1580 |
Posted: 02 Jan 2018 at 10:16pm |
PM I have some used ones.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8986 |
Posted: 02 Jan 2018 at 10:40pm |
why not send yours off for rebuilding? I would think new tips from Bosch would be as good as it gets unless doing something more than farming.
Posted: 03 Jan 2018 at 7:25am |
8030-50-70 are all the same !! Have a diesel injection pump repair shop of your choice replace the tips with new and adjust them to 3600 psi and you are good to go. Install them with the drip line towards the valve cover.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 03 Jan 2018 at 7:33am |
I have new ones in stock, and I take the cores back in. But, he wanted a different route than my shop.
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 03 Jan 2018 at 8:06am |
Why would someone not want the best....? Probably reasons that aren't any of my business. I learned the hard way........Darrel |
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 03 Jan 2018 at 8:10am |
Wink I am a Russian Bot |
Posted: 03 Jan 2018 at 9:05am |
The part that bothers me is "find some injectors that work even BETTER"........ better than what ?? Those Bosch injectors work just fine, but they don't last forever and need to be replaced occasionally.
injpumpEd
Posted: 03 Jan 2018 at 9:55am |
I think he meant if he could find some tips only, he would like that better. I've had so many times with these injectors that someone will try to do a low buck "rebuild" and not lap the mated surfaces, then they end up leaking externally. This is one reason many shops won't sell just the parts anymore.
Lonn
Posted: 03 Jan 2018 at 11:12am |
AllisandGleaner
Posted: 03 Jan 2018 at 1:31pm |
What I meant was I had my diesel injection guy check mine and out of the bunch I had one with a bad tip. He's been in the business for 50+ years and has been rebuilding the majority of our pumps for years and all of our injectors we haven't had any problems out of any of is work. He had just told me that if I found him a replacement tip he would put it in free of charge and I didn't know if anyone had one in old inventor because I got a whole set for a 8010 but they have a smaller opening. That was all that was meant by better was the fact he was going to install if free of charge.
injpumpEd
Posted: 03 Jan 2018 at 3:37pm |
He can't get nozzles? The 8010 is a totally different setup, same as 6080, nozzle is different, and retaining nut too, to fit heads with copper tubes. I have some new old stock nozzles for an 8030/7045 etc. They do actually call for a smaller hole nozzle than the 8050/8070. What part number you looking for?
AllisandGleaner
Posted: 03 Jan 2018 at 5:29pm |
74036651 and he is currently searching for me one. I knew that the 8010 and 6080 was the same with a .33 mm orifice and the 8030 has a .36 mm orifice.
Edited by AllisandGleaner - 03 Jan 2018 at 5:40pm |
injpumpEd
Posted: 03 Jan 2018 at 8:26pm |
the 4036651 is an AMBAC NBM770022. I'd sure think a good pump shop would keep them in stock. I keep 12 on hand.
AllisandGleaner
Posted: 04 Jan 2018 at 5:05pm |
He found me one today now I just got to go pick it up.
