3-point hitch for D17 series 4 from 170/175
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Topic: 3-point hitch for D17 series 4 from 170/175
    Posted: 04 May 2018 at 9:27am
Would a 3 point hitch assembly from a 170/175 fit on a series 4 D17 that had a snap coupler setup?
It looks the upper and lower arms lift arms would need to be changed, along with the draw bar carrier. Is there anything else that would need to be swapped out?
Thanks
D15D, D17G, 170G, 175D, and two 5050FWA
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 3:48pm
SOme linkages for the traction booster, etc. and the drawbar anchor plate where the snap coupler bell/spring bolts to the rear end housing.
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
