work saver three point for wd 45 and
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: work saver three point for wd 45 and
    Posted: 01 May 2022 at 10:44pm
anyone have one of those hitches on there tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 4:39am
I have one of the older ones that had problems with the axle that the lower arms rotated on.  I see in the new ones have changed that part to a stronger weldment.  Problem was in the outer bracing set up, would break off the outside the arms braces...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 9:06am
does yours on bolt right on were the adjustable drawbar bolts, and the drawbar is held up with it ?   does not appear that these are in stock anymore with anyone so think i will fab one up
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 1:02pm
have you tried O.K. ? .......  the might have more data..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 5:06pm
Yes, and I had to "move" one of the holes, to make it bolt to the DB...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 8:54pm
with all the ordering i do each day keeping parts  here and ones i sell  as soon as it  says  call for avaiblity  or low stock it means  you aint going to to get it this year or its substituded with some thing like it .  but really do not mind welding up my own like in the one picture only with sway blocks instead of the sway arms  but its allways nice to start with some pictures or measurements so that a guy doesnt have to spend so much time figuring out all the geomentry so that thing s operate good .    lets see some pictures  if any one has  time for some
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2022 at 9:28pm
worksaver no longer makes 3 point hitch kits... You go to their site and all gone.. but if you sneak in the back door you can find the "obsolete manual" for the WD45 and others.
https://www.worksaver.com/discontinued-product-manuals
Edited by steve(ill) - 02 May 2022 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 9:24am
thats what i gathered thats why i  am looking for some ones on a tractor "pictures" so i can build my own i like that design the best,  not many pictures on the internet
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 9:00pm
I found someone selling the two lower arms and the upper link from a Ford tractor for a reasonable price.
Using ~3/4in+ bolts, nylon lock nuts, and washers I mounted the tractor end of the lower arms to the extra holes for the regular WD tongue hitch bar height adjustment bracket (basically the largest bolts the fit through the existing bracket holes. Regular Class 1 pins are a little larger). I drilled holes in the two lower bars to fit a couple of Kubota three point turn buckles from Tractor supply (although a pair of steel straps with extra holes for height adjustment and pins would work too and save cash). The factory lower arm center holes for the turn buckles was too far forward and the geometry did not work out, hence the extra drilling, get/use a titanium bit).
This setup won't work for plowing (no draft/weight transfer bonus) but I can "lift stuff up and put stuff down".
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 10:03pm
that looks like a good keep it simple one
This page was generated in 0.322 seconds.
