help ID this trencher,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: help ID this trencher,,,,
    Posted: 21 Oct 2022 at 4:34pm
  OK, I've had this Ditch Witch C99 trencher for the longest and been stored in the barn for a few years.  A friendly contractor had the engine completely overhauled for me and I only used it to dig a trench for a water line 4 or 5 years ago. I remember the dang carburator giving me fits back then,,,SO, I want to order a replacement carburator for the engine. It now has an updraft carb but I ain't found one on Ebay or amazon,,,plenty of side draft carbs but no UPdrafts,,,,??
 I'm thinking the engine is a Wisconsin single cylinder with  numbers on tag==AENLD-2---
 408004--5909185---
 Tag on the trencher frame is C99---SN113107
 It would NOT be a big issue to build a different "intake" to use a newer side draft carb which are a dime a dozen on Ebay ($22) I got some pics to see if someone can ID the carburator,,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2022 at 5:45pm
DJ...
use Google " AENLD-2"
you'll get a zillion 'hits'.....
Jay
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2022 at 12:50pm
Darnit, Joe-
If you wanna us to identify the CARBEURATOR...
then git in there and post a picture of the CARBEURATOR...
from that angle and distance, it could be ANYTHING... Zenith, Tillotson, Marvel Schebler, Bendix...
Good thing it has a starter-generator on it, my buddy has one of those trenchers on steel tracks... rope start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2022 at 10:35pm
 Chit Dave,,,ole Buddy,,,ole pal,,,,,,LOLLOL
 I WAS SOME PRE-MATURE ON THIS ONE AS i AM GOING TO REMOVE IT TAMARROW,,,LOLLOL
  I have bad memories with that carb as it was always tempermental SOB even after a complete clean out and new carb  kit The contractor told me that he put a kit in it also,,,!!! I'm thinkin bout machining two plates with the bolt pattern of the intake but with a straight 1" nipple welded between the two flanges to mount a carb that is NOT an updraft
 I did find some "NEW" rooskie made carbs on Ebay that are listed for the Ferguson TO 20 tractors,,,,reckon one of them would work,,??
 That starter is also a generator and is 12 volt and works many wonderfulsClapClap
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2022 at 2:42am
gits you another engine for it....a more modern one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2022 at 7:49am
 Well, CHIT,,,,and,,,,and,,,I thought he was my buddy,,,,,,Wink
This page was generated in 0.527 seconds.
