A-C B, Location of Upper Generator Bracket
txtractorguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote txtractorguy Quote  Post ReplyReply Direct Link To This Post Topic: A-C B, Location of Upper Generator Bracket
    Posted: 11 Apr 2018 at 7:06pm
I'm surprised the upper generator bracket is attached to the exhaust manifold as shown in the picture.  Is this correct?  Mine was mounted just like this as shown by the "L" shape I drew in red.  The ear on the exhaust manifold where this connection is made was cracked on mine.  I'm not surprised.  This doesn't seem like a good way to make this connection.  uploads/15483/Upper_Generator_Bracket.jpg
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 7:16pm
Yep thats correct!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 7:41pm
That is correct. Should not put any stress on the exhaust manifold unless the stud is loose in the block.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2018 at 7:45pm
I just did some work on mine and that is exactly the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote txtractorguy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 8:57am
Ok, thanks.  I still think it's a bad place to put this bracket.  I think, over time,  the vibration from the generator would fatigue the ear on the exhaust manifold......but maybe not.  Thanks again.  I'll proceed to put my new bracket back where the old one was.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2018 at 11:06am
You generator should be running smooth if it's vibrating you might want to get it to an overhaul shop before the armature contacts the field magnets and it self destructs. I converted my C and CA both to 12 volt alternators they don't even have upper brackets any longer. Just a lower bracket.
Edited by Dakota Dave - 12 Apr 2018 at 11:08am
This page was generated in 0.411 seconds.
